Lowering
- YYgirl
Lowering
Hey guys, if I want to lower my car, do I need to get a mechanic to do it? because my friend said he can do it, but i'm not sure if it's safe. hehe
I want to save some money on labour. hehe
- elmo
lowering
lowering is easy and safe as long as it is done right. Just remove your old spring and replace it with a lower one, easy and anyone can dop it if they try.
Now on the other hand...
lowering blocks, cut springs or worse, heating the springs to make the car drop is a definate no no. aswell as illegal and unsafe. But extremely cheap and a good way to reck your suspension.
Buy the right springs and your mate should have no trouble doing it, otherwise don't let him near it.
I found labour very expensive too when I got mine lowered about a year ago. The cheapest I found meant a trip to the Gold Coast to see the guys at Mermaid Suspension at Mermaid Beach for $160 incl GST. The next cheapest was like $220! They have lowered several FTOs and seemed to know what they were doing. They recommended I also get better/upgraded bumpstops at the front from memory which I did to be on the safe side and it was only an extra $70 I think. I've only been back once to get the rear end bolts etc retightened due to squeaking all the time but that is not a reflection on their workmanship I'm sure. So if you can spare a few hours to make the trip I'd definitely recommend them.
replacing your springs really isnt very hard...i replaced mine....you just need a few wrenches (socket wrench kit if possible), a set of spring compressors which are something like $30 at kmart, wd40, pin stands and a few hours of work...
its a pretty messy job ... you just have to make sure you put everything back on the way it came off and secure everything .... get a good wheel alignment afterwards...
theres a UK website somewhere that tells you exactly how to do it...cant remember the link off the top of my head though...
- elmo
shocks
My car is 70000K and wilkinson suspension told me shocks are ok as long as you only lower a bit. Or "level" the car, which was what I was gonna do.
They actually said everything is still in really good condition under there which suprised me cause everyone kept telling me that the suspension on imports usually needed replacing.
- YYgirl
- JSP-INC
apexi
I have Apexi GT's but like they're bout 50-55mm lowered springs..
And the ride.. lol, terrible and teh struts aer bottoming out, but like i've had these springs on the standard shocks for bout 2 years.. only in the last few months has it got unbearable..
Getting new shocks next week!!
lowering 35mm is ok, but u might find that it bounces a bit, and the ride will be harsher but not overly!!
- elmo
lowering
depends what sort of ride your after hey. you cant just say better.
A slight amount of lowering will make the suspension slightly firmer and flatter so your car will handle better. In your opinion this is probably not a better ride.
If it is a cushier ride like a family car that your after then the news is all bad. Youd probably need shocks and springs, maybe even dual rate to get the right handling.
