Would 235/40/18 front 275/35/18 rear wheels fit a fto lol
I dont think they will but just asking incase
2354018 front
2753518 rear
Thanks
2354018 front
2753518 rear
Thanks
Re: Would 235/40/18 front 275/35/18 rear wheels fit a fto lo
275 wont. 235 will, but we'd need to know the offset of your rims before anyone can give an answer.
- bjk
- Totes
275 might if you don't mind being at 4x4 height.
its 18x8 with offset of 40
The problem is that its a staggered fitment so the back is a bit wider unfortunately which idm but want to see if the back would fit anyways cause im thinking about getting them.
thanks
thanks
- bjk
- Totes
The answer you're going to get is "don't bother". Unless you want to use spacers and flares.
Personally am not abject to doing things predominantly for style, but I'm in the "why stagger backwards on a FF" camp too.
fair enough, i rather not have staggered thats what i found. Thanks thoughbjk wrote:The answer you're going to get is "don't bother". Unless you want to use spacers and flares.
Would anyone know what the max rim width would be for the rear of the fto if i were to change the tyres? thanks
- bjk
- Totes
There are a few of us on 9" and 9.5. Toby got some 10 I think it was. He pulled the guards a bit though. Depends on offset as there's not much room on the inside.
Alright cheers
- bjk
- Totes
Would recommend an offset of 30 or less for anything 9" wide or more.
- prageeth
I have 235/40/18s on front and rear on mine. Front tyres touch the inner guard while in a full lock. Next time I will consider putting narrower ones to the front. Cheers.
