Version R spring rates?
- Herron
Does any one know the version R spring rates? or a close estimate to what they would be?
I can't find anything on them.
Re: Version R spring rates?
You didn't look very hard
Bennoz wrote:You can have springs made relatively cheaply. All you need is an old spring, the height you require & a spring rate. Standard is 2.6kg/m front & 1.6kg/m rears. Try companies like Eibach - their springs are cold rolled too, superb construction.
http://www.eibach.com.au
- Herron
So both a GPX and a GPvR have the same spring rate then?
Pretty sure they do. What do you need the info for? If they are different then it wouldn't be by all that much.
I'm guessing that the only variation would be the Nakaya tune which had Ohlins shocks, so that would be likely to have slightly different spring rates possibly, but I'm not 100% sure.
- Herron
Im thinking about going coil overs, so i wanted to know the stock spring rate.
- rock_it
Didn't the vR come out with Tein Coilovers... That were usually removed when compliance got done?
So spring rate could actually be different.. Maybe a little stiffer..
Where'd you hear that? I've never heard that beforerock_it wrote:Didn't the vR come out with Tein Coilovers... That were usually removed when compliance got done?
Interesting if they did.. if they did get pulled out for compliance then they should be given to whoever bought/imported the car.
Nah, didn't come with Teins. But they did come with uprated shocks and springs. Different part numbers to the GPX/GR variants.
- Shhtuart
If you can wait 5 days I'll tell you exact specs from the actual booklet.
There we go then. Either way, just get adjustable coilovers and go softest setting for street use.
Had a set of Cusco's before. Loved them. Delivered pizza in my FTO that had them actually.
Couple of the guys love the BCs as well, and Teins are pretty popular too.
- rock_it
Hmmm.. I thought so..
Pretty sure Dwayne's came with Tein... And the ones I got were meant to be out of a vR as well.. But meh, probably just me being wrong..
Dwayne's came with Tein HA's. Not the coilovers, the shock / spring combo that ended up in my car for years. Recently binned.
- rock_it
Ahah ... Well there you go ...Bennoz wrote:Dwayne's came with Tein HA's. Not the coilovers, the shock / spring combo that ended up in my car for years. Recently binned.
