All 6 indicators dont work
JacksonChater
Post by JacksonChater »
I was driving happily this morning and I turn my blinkers on for turning but nothing happens? This stick moves but there isn't that clicking noise when indicators are on. The green arrow doesn't flash either and the hazard lights aren't working either. I've changed the fuses multiple times but they keep blowing
Re: All 6 indicators dont work
You have a short somewhere. Could be a pinched tail light wire or indicator wire.
Most likely tail light, I've had that problem before.
JacksonChater
I'll go check that now man
JacksonChater
Yeah so I pulled both the tail lights off and the green and blue wire to the right indicator lamp was squished in the screw hole, wire doesn't look good
If you have to/can then rewire it. If not, just clean it up as best as possible and heatshrink it/tape it as best as possible. Have you got pics of it?
Mine was crushed and crappy and all I did was smooth it all out and run some tape around it to stop it getting fried, has been fine ever since.
JacksonChater
Yeah I rewired it so it's all good now, they work
Holy sh*t! The entire electro technological knowledge of Daniel actually worked!
And to think I was gonna mock him for continually going on about a pinched wire... I take my hat off to you sir!
Haha, I'm actually not too bad with wiring now. Can do basics! Even got myself a new multimeter 8)
Pretty good one, too!
Daniel2019 wrote:Haha, I'm actually not too bad with wiring now. Can do basics! Even got myself a new multimeter 8)
Nah, it was probably just a Fluke.
:(D):
