Need some help installing aftermarket HIDs
TomHenman
Post by TomHenman »
So my HID replacements finally came and I'm currently sitting outside with the bumper off and lights out a bit confused as to where everything is meant to go..
Anyone have any experience replacing the existing version R HIDs that could shed some light on what goes where?
Re: Need some help installing aftermarket HIDs
What exactly are you replacing? Bulbs?
TomHenman
Post by TomHenman »
The bulbs and ballasts
This is where I'm having trouble, does this end of the wiring need to be attached to the plug on the existing ballast?
(ballast plug)
and if so how is it attached? cut and soldered?
And also, does the actual bulb sit behind this section? held on by the 3 hexagonal screws?
Sorry for the retarded questions..
if you are installing completely new ballasts you need to get rid of the old ones. Can't have two sets of ballasts. And what bulbs did you buy? The one's in the photo don't look right to me. (From what I can see/remember)
Factory HID bulbs are D2S
If you flip the light upside down I think there should be a rectangular panel held on with torx bolts. Don't remember if you need to remove the back panel as well.
TomHenman
Post by TomHenman »
Vectose wrote:if you are installing completely new ballasts you need to get rid of the old ones. Can't have two sets of ballasts. And what bulbs did you buy? The one's in the photo don't look right to me. (From what I can see/remember)
I understand that I'm replacing the ballast in its entirety but how do I connect the highlighted wires into the plug that the equivalent from the existing ballast used to connect to?
TomHenman
Post by TomHenman »
and yeah they are D2S
If the new bulb holder fits in the factory spot the only thing you actually need to modify is the wiring from the harness to the ballast.
And what I would do is cut the wiring off the old ballast to utilize the factory plug then solder the new ballast's power input to that plug. As I do not believe in cutting the factory harness. By all means you could just cut the plug off and solder it directly but I don't like doing that.
If the new bulb holder does not fit, you will need to pull the bulb out of it (Unless its a complete unit and not a true D2S bulb) and utilize the factory wiring again and chop it off at the ballast and solder the new wires to it.
Bit hard to explain what to do exactly without showing you though.
