FTO Front bumper
prageeth
FTO Front bumper
Post by prageeth »
Hi
Can I install a series 2 front bar to a series 1 bumper? Series 2 front bumper has 2 round lights each side and series 1 (old) bumper has 1 oval shaped indicator light in each side.
I was thinking on removing the old typed bar and install a new one if that fits easily.
Your advise will be much appreciated.
Cheers
Re: FTO Front bumper
WTTC
We call them pre facelift and facelift.
Yes you can, you will need to buy new lights and make up custom brackets for them. Or get a facelift reo and then its a straight swap.
Actually, the indicators bolt straight up to the bar, so you only need to make a bracket for foglights if you want them. The bigger difference however is the parkers. In prefacelift these are in the oval indicator/parker/foglight unit. In the facelift howevr, they are in the headlight. You can either modify your headlight to take a parker bulb (there is a DIY on the site somewhere), or locat parkers somewhere else.
What sort of facelift bar are you looking at? Stock or aftermarket
