Hit mivec then suddenly stalled and now misfires???
Hey guys. I have a 98 fto gpvr auto, I accelerated the other night, went to the red line, then all of a sudden it stalled. I started it back up and now it's misfiring?! Please help. Any ideas?? If not any good fto mechanics in melbourne??
Thanks mark
Thanks mark
Re: Hit mivec then suddenly stalled and now misfires???
Throwing any error codes?
Could be heaps of things..
- Shhtuart
Redlined it? These cars have a limiter so it wouldn't have gone past that.
Could of slipped a tooth on the timing belt lol
Hey guys. Sorry I'll explain a little better. It went to 8500rpm, I heard a noise. Then it stalled. Now it starts but misfires at idle. It's random. Plugs, could and belt are all new. Any help would be greatly appreciated. Could a worn or broken lash adjuster do this?
- Shhtuart
Could be anything man. Last time I got misfiring was when I didn't plug my map sensor back in after changing the spark plugs. Check you haven't blown a vacuum line off anywhere.
- Nacho
Was the car warmed up and driven for at least 20 mins? Or still cold?
Wont hit mivec or rev higher than 6,000 unless at operating temp. Check error codes.Nacho wrote:Was the car warmed up and driven for at least 20 mins? Or still cold?
Check coils and leads, check vacuum lines.. could be heaps of things including timing belt slipping.
Anyone else got ideas?
- SchumieFan
sh*t fuel, pinged it, busted a valve
Yeah I didn't wanna be the guy to say itSchumieFan wrote:pinged it, busted a valve
- ZFL45H1
Ive done it bent and snapped the same valve although it sounded like a quad rotor and would still hit mivec if that helps
Ouch...
Although 8,500 is too high to rev.. there's a redline for a reason
- ZFL45H1
It's fucked, buy my engine
Thanks guys. I really appreciate the advice. I'll pull the coils off and replace with a spare set I have. Also will check timing. If all else fails heads come off. How do I check for error codes? Obd1?
Nah, just see here -Markjh27 wrote:Thanks guys. I really appreciate the advice. I'll pull the coils off and replace with a spare set I have. Also will check timing. If all else fails heads come off. How do I check for error codes? Obd1?
http://ftoaustralia.com/v3/viewtopic.php?f=21&t=14667
To be honest, since it happened right after you took it to 8,500, my money is on a bent or fucked valve. Time for a rebuild or engine swap I reckon, although I hope we are wrong.
- ZFL45H1
Instead of taking the head off get a pressure test when it happened to me a cylinder had 0psi
