Weird ugly mivec Sound
- Kashikhan55
my mivec used to kick in just find and smooth but over the lat 3 weeks or so everytime i hit 5500rpm mivec kicks in but has a horrible sound and like its lagging it isnt smooth kick and just sounds plain horrible.
oil was changed just recently so don't think it couldnt be anything to do with oil
any other reasons or anyone else had that problem before?
Re: Weird ugly mivec Sound
What oil did ya put in?
- Kashikhan55
destinationtoby wrote:What oil did ya put in?
castrol gtx 15w40
https://www.malz.com.au/images/rp_280x2 ... 1355974102
Oils too thick, need 5W30.
Castrol Edge Sport/Titanium 5W30 is the best.
- Kashikhan55
PHIL069 wrote:Oils too thick, need 5W30.
a quick search shows it just might be the mivec tappets needing a good clean apparently. after which i will flush the engine oil and put the oil recommended above by you
thanks
lets see if that solves the problem
Did it only start after you done your oil change?
- Kashikhan55
no, i got service done about a 2 months ago and couple of weeks later the problem started.PHIL069 wrote:Did it only start after you done your oil change?
at first it was fine after the service (oil n filter change etc) and 2 weeks later mivec started to die basically
Change your oil to 5W30.
It has nothing to do with your tappets.
Mivec engages with an electric solonoid which lets oil through to engage the mivec cam lobes.
Your oil is too thick and it can't get through the intraget oil channel system.
If oil change won't fix it then I would be looking at possable valve issues (caused by the oil being too thick)
So, change your oil buddy
- Kashikhan55
i will do that asap (next week) and mention here how it goes.PHIL069 wrote:Change your oil to 5W30.
thanks bro
- shadowarrior
- Tightarse
Yep, nothing to do with tappets. Tappets give the distinct and annoying tick tick sound. Easy to identify when idling.
Don't change your oil to 5w lol. I've put 15w before and its fine. If u want to change oil go 10W.
Check the battery terminals and also check the alternator one as well.
- Kashikhan55
okay so i need some definite answer to as to what oil i should go for as everyone seems to have their opinion whats the best oil i can use thats not thick10w? or 5w
Go with a Shell Helix 10w40 or equivalent, it's a semi synthetic. If you want to front up for the extra cash and more frequent oil changes then go with a fully synthetic oil like Castrol Edge.
Just so you know though if you go from a non-synthetic oil to a fully synthetic, sometimes you will get leaks.
Use a decent oil, not magnatech etc.
- Kashikhan55
^ thanks 10w it is
- kiz
- SA Coordinator
Yea I'm running Castrol Titanium Edge 5W-40 in mine, no trouble. Changed every 5,000km but the oil is usually $50-$80 for 5L so not cheap :/
1998 Mitsubishi FTO GPVR AERO
- Kashikhan55
cost wise its fine for me as long as the oil is good i want best oil
Thanks silversilverGPX wrote:Don't change your oil to 5w lol. I've put 15w before and its fine. If u want to change oil go 10W.
That's what I meant to say , 10W30, it was a long day yesterday
Sorry Kashikhan55
- Kashikhan55
all good
ima go get myself 10w30
thanks guys
thanks guys
I use Castrol Edge 5w-30 personally. Find it great.
