Drop links hitting strut.
- Shhtuart
My drop links were gone so I replaced them with new ones, identical to the last.
It has definitely improved the steering but the drop link on the drivers side smacks off the bottom of the strut when I go over bumps.
It only happens when the wheel is straight, if its turned a little it doesn't hit. It also did this before I replaced it.
I have replaced the sway bar bush on the drivers side but not the passengers side.
Am I right in assuming that the bush on the passengers side that is unchanged is enough to cause the sway bar to move over enough to hit the strut?
I have a gpvr so the drop link is in the suspension arm under the bottom of the strut.
Re: Drop links hitting strut.
You have them in the right way round yeah?
- Shhtuart
They only go 1 way...
No actually two ways, u can have the bolts facing inwards or outwards.Shhtuart wrote:They only go 1 way...
- Shhtuart
Have you seen gpvr front drop links?
Yeah, I put tylars coilovers in and his was a gpvr
I fkn hate when dropkicks hit my slut
Well stop hitting your slut then?destinationtoby wrote:I fkn hate when dropkicks hit my slut
- Shhtuart
I am 100% sure that the gpvr ones can only go one way. Can another gpvr owner verify please?
Post up a picture perhaps...
Sahin wrote:Yeah, I put tylars coilovers in and his was a gpvr
Lol I actually wrote "is" and then backspaced it and wrote "was" lolVectose wrote:Sahin wrote:Yeah, I put tylars coilovers in and his was a gpvr
- payaya
You mean the suspension assembly your control arm fixes onto not your strut?? If that's the case you will notice your sway bar is bent and you need to straighten it out or get a new one.
