Leaking flywheel bolts
vanadinite
Post by vanadinite »
Back story:I'm putting in my newly acquired LSD gearbox.
Engine has never had any oil leaks from the engine/gearbox area.
Rear main seal hasn't ever leaked in the past.
Where I'm at: So far I've got the old transmission out. Engine is tilted on 45 degree angle pointed towards the ground.
Possible Problem: When I removed the flywheel, engine oil came free flowing out the lower flywheel bolt holes.
Question: Is this normal, are the flywheel bolts open into the engine, hence the leak?
Re: Leaking flywheel bolts
Mine didn't leak when i changed my clutch and got my flywheel machine
vanadinite wrote:Question: Is this normal, are the flywheel bolts open into the engine, hence the leak?
Yes this is normal, they are open to the engine. When reinstalling you need to use a loctite/sealant on the flywheel bolts otherwise these will leak.
Ask daniel, he is our flywheel expert! :lol:
PHIL069 wrote:Ask daniel, he is our flywheel expert! :lol:
Just get rid of the flywheel, you don't need it.
vanadinite
[/quote]Just get rid of the flywheel, you don't need it.[/quote]
Yeah but then how would all the flies get around?
Yeah but then how would all the flies get around?[/quote]
You're a fuckhead! Lol
ash1987
Post by ash1987 »
You're a fuckhead! Lol[/quote]
takes one to know one :-P :troll:
1998 gpvr aero
fraz91
Hair-do
Post by fraz91 »
ash1987 wrote:
Sahin wrote:
vanadinite wrote:
Daniel2019 wrote:Just get rid of the flywheel, you don't need it.
You all fail at quoting...
