Non airbag indicator stalk with rear wiper stalk
Private Sales Only
Lawso
Penis Fingers
Post by Lawso »
The indicator cluster off a non airbag FTO with the rear wiper option. Going to attempt the conversion, and have been told that the one off my busted car won't work as the plug is different due to the airbag.
post to 2034 please :)
BorepYano
Re: Non airbag indicator stalk with rear wiper stalk
Post by BorepYano »
the combo switch?
good luck, Taz is also chasing one, thought I had one... but no :(
Lawso
Penis Fingers
Post by Lawso »
BorepYano wrote:the combo switch?
DAMN!
Is it just the plug itself, nothing to do with the arms attaching to the steering column?
From putting the Momo on my RVR which was non air-bagged, I simply had to make up a way for the horn to work as there is an extra attachment (clock spring I believe)
in front of the stalks and behind the steering wheel...
I reckon you could get away with using yours from the GX and simply cutting/ swapping plugs.
Can have a look at it for you when you get the other car, see if it's do-able...
Will check on ASA tonight for a diagram, see if there is anything obvious
As is, you will need to do the same trick I did with the momo as your other one doesn't have an airbag... correct?
Lawso
Penis Fingers
Post by Lawso »
Astron_Boy wrote:Is it just the plug itself, nothing to do with the arms attaching to the steering column?
Correct mate. not looking to swaqp the momo airbag steering wheel over, i just want the rear wiper! i need it in my street
Why don't you want the momo steering wheel?
It's an easy swap and looks much nicer...
Can do both once you have the car pending some testing with the multimeter.
Steering wheel I can definitely do easily.
Rear wiper switch can't be much harder, I've done worse electrical things in a car.
Just a few extra wires and what not, should be easy enough to do.
Doesnt he also need to replace rear windscreen?
his GX shell has that, pending it doesn't shatter.
I have in the air dibs on Dwaynes spare for when we have the sill rust fixed. :lol:
Ah yeah forgot he had a rear wiper before.
Onwards, Lawso!
Lawso
Penis Fingers
Post by Lawso »
Astron_Boy wrote:Why don't you want the momo steering wheel?
i'd want a steering wheel similar to craigs (in the blue one), but saying that, might swap it around for the meantime...i really am not sure. things that aren't really important like that are tossed so high in the air at the moment i'm not worrying about it to be honest. will get to it when i need to basically.
