Facelift Foggies
Facelift Foggies
So I'm on the hunt for some nice foggies, I remember a while ago seeing somebody link to some lights from a VW of sorts, that had projector Fog lights, and an LED halo around it for driving lights? Does anybody know of these, and if they would fit?
Cheers.
Cheers.
- aza013
- NSW Coordinator
Re: Facelift Foggies
Check with Dstocks .
dstocks wrote:If you are only after stock facelift indicators, I have a set in the garage ($90). I would normally sell the foglights for $120. $300 is a rip, so dont pay that. Ive got a set of the factory upgrade cibie lights that replace the stock fogs and these are even rarer. Most I would ask for those is $150. People that try and charge that much dont deserve to win out.
I checked with dstocks the other week, what I really want, is some thing that has both foggies, and park lights in them...
- Shhtuart
You might be able to modify the fogs with those angel eye rings but I don't know how that would lookTechnikhaus wrote:I checked with dstocks the other week, what I really want, is some thing that has both foggies, and park lights in them...
Are they the right size for the hole though.
That's what I'm wondering, does anybody know the dimensions for the holes in the bars?
About 7.5cm (give or take a half a cm)
They look sweet, I likeTechnikhaus wrote:These are the ones I was thinking of:
http://www.ebay.com/itm/98-99-00-01-02- ... 36&vxp=mtr
This listing shows measurements, is anybody able to measure their facelift bar to see if it will fit please?
http://www.ebay.com/itm/Universal-Fit-F ... 66&vxp=mtr
- den0va
I think it would be a tight fit, probably need some slight modifications to make it fit right. Nonetheless, the outcome would definitely be worth the work.
I'm very tempted to just buy it...
No one's able to measure for me?
I'd measure mine but mine are aftermarket
Even the holes in the bar would be fine if possible, i just want to see what will fit...Sahin wrote:I'd measure mine but mine are aftermarket
Ill post the dimensions up in the morning if no one else does by then mate
Sweet, thanks
By the looks of things, they should fit. Even if it is with a bit of modifications...
It will be in a Rod shop anyway...
Just measured it, approximately 82mm.
