LED update
- SilentBob
It probably cost me 80 bucks or so (I used extreme bright leds for the main pod they are nearly 8 bucks each)sbe8888 wrote:Dash,
I love your LEDs as well....
How long u took to change all the leds?
Also, how much u spent?
About 5 hrs so far (maybe more) half of that was just figuring out what I could use and the layout etc.
Chopsticks, I'll write up a tutorial soon, you may want to have a go yourself, it's not too hard.
Gav, I hope to write a tute this weekend, and yes G1, I have seen Johns site in the U.K.
That's why I gave it a go, I like the look of his pics, I believe mine has come up way better though
He is setting up 'kits' of some description, bugger that, you can do it yourself loads cheaper.
There is no tech info on how to do it on his site, just a link for his kits.
- SilentBob
- dannyboyau
Hey Dash
Just checking which shop you bought your LED from, The size of the LED and other components needed.
Ive taken apart my DASH before so fairly familiar with the set up. i originally took the globes out and put blue sleeves over them, however it was not bright enough. If you can let me know where to get the stuff and exactly what i need, hopefullly i can figure out the rest!
Thanks in advance!
Thanks in advance!
