Got problems with your sig??
- GPXXX
If you are having gibberish HTML codes appearing on your signature, you can fix that by going into your signature section of the profile and click on the <> symbol...
Then just edit the singature to however you want it to appear...
Hope that helps...
Hope that helps...
- pagan
- Luca
Hi Barfy ... here is how you do it.
As GPXXX stated. First click on the button that looks like <>
Then type:
the bit in the quotes is the location of the image. I've posted something in my signature to demonstrate it is possible.
I typed ...
Let us know how you go
Luca
Then type:
Code: Select all
<img src="...">
I typed ...
Code: Select all
<IMG src="http://i5.photobucket.com/albums/y168/LucaGnezda/3doh.gif">
Luca
- smorison
- The Godfather
<IMG src="http://memimage.cardomain.net/member_im ... 9_full.jpg">
barfy put a < at the front and a > at the end and it will work just like above
- Luca
I think you might have a return character in there or something
that is exactly what I have.
Code: Select all
<IMG
src="http://memimage.cardomain.net/member_images/3/web/603000-603999/603117_9_full.jpg">
- Luca
- Luca
ok if I copy the code above into my sig, it breaks. But if I then go to the code and double backspace between 'IMG' and 'src' then insert my own space it all works
Trust me this should be easy
- ph3var
I just did a small test and I think you should paste it then delete the space between "<IMG" and "src" so it is on one line then add the space again.
This will remove the newline and make it wrapped text and should work.
Nice F*ing interior btw.
Custom purple 1995 GPX manual
