magna bits?
Re: magna bits?
The water lines are reversed?
I already have a Magna TB fitted but when I manually open the butterfly I can see that the opening is smaller on the plenum than the TB
Re: magna bits?
Yip need to change over water housing straight swap over it all matches up
Re: magna bits?
spetz wrote:The water lines are reversed?
Not so much reversed, they just come out on different angles
Re: magna bits?
Wow thats actually a lot bigger when you put them side by side!
Re: magna bits?
Yip and much cheaper and easier than machining current tb and finding butterfly to suit
Re: magna bits?
Shame i cant do this, as i have TCL, unless theres a magna with that option?
Re: magna bits?
Sure is
Re: magna bits?
Ooooooooooooh!
That would be cool!
I wonder if they're rare!?
Re: magna bits?
Doubt it. But why do this unless you have ecu to suit or plan on boosting
Re: magna bits?
I have an ecu to put in, just waiting to get my car back.
Remember I asked you for diagrams on your wiring.
Which I still have to get back to u with pics. Just haven't had the car with me so I haven't bothered :lol:
What machine would be required to bore out the manifold hole? I think the fitters at work might have a machine.
Re: magna bits?
Easy can either machine or use finger style belt sander will ground it in no time
Re: magna bits?
Is it just the initial inlet that needs grinding out?
Is it that simple?
Re: magna bits?
Can do will work fine. Can also take meat out of whole thing and ports to heads too and remove plastic inside but thats really not needed. Just doing tb and mouth will give plenty more air as with a aftermarket intake that area is what bottlenecks
Akys
Manual Conversion
Re: magna bits?
Post by Akys »
PHIL069 wrote:
Bennoz wrote:Just the 6A13. Shane001 did one to an FTO plenum on his racecar, all it needed was the mouth ground out, same as mine.
I have a 65mm Magna throttle body and a ground out FTO plenum..............sitting in my garage for use one day...........got it off of Akys...........Hmmmm, still need to give you $20 moar Akys, maybe next bonfie, if you show.
Should install it. almost forgot bout the $20.
Re: magna bits?
^But they are all saying I need an after market programmable ECU to install it^ :scratch:
Re: magna bits?
silverGPX wrote:Shame i cant do this, as i have TCL, unless theres a magna with that option?
Not sure if the Magna range got TCL but most later Veradas (KJ onwards) got TCL
adzski
Re: magna bits?
Post by adzski »
i have a question about the tb.
as mentioned before the magna tb makes problems down low and makes the car run rich, and would need a after market ecu?
i was wondering would the RPW TB make the same problem? its the same size 65mm. abit pricey for what it is though. and is it worth the coin? my guess is no.
http://www.rpw.com.au/shop/index.php?pa ... t&Itemid=1
Re: magna bits?
Yes basically same thing. Only needed if going force induction tbh
