As I understand it the stock pump is runs off a pulley and is basically a propeller housed in a metal housing bolted on the side of the engine. I saw a photo of a stock unit for the FTO and this is basically what it looks like.
I have been told by a few people that an electic pump is a cheap way to gain 5 Kwatts, since you reduce the load of the water pump on the engine and divert it to the electical system.
Problem is that having looked at the EWB kit, it looks to be a complicated job. The pump sold by EWB is simlar to a small water pump. How this would replace the housing that is fitted to the side of the engine I cannot imagine.
I think I'll need to have a closer look at the workshop manuals as see if the inlet and outlets of the moulded area where the stock pump fits, can be fitted to have pump hoses connected into it.
Thoughts?
Marty Thygesen (jc133480)
mailto:martin.t@hushmail.com
![Razz :P](./images/smilies/icon_razz.gif)
