18's on FTO
- APZ-312
18's on FTO
hey guys.. i was thinking about purchasing 18 inch lowenhart's for my fto.. the specs for these wheels are:
front: 235/40ZR18
rear: 245/40ZR18
would this rub? any comments?
front: 235/40ZR18
rear: 245/40ZR18
- APZ-312
- APZ-312
ok
finally i found wheels that come closest to what u guys have mentioned. LoL
ok they're D'Vinci and here are the figures:
18x7.5 wheels.
5x114.3 stud pattern
Tyres either 225-40-18 or 235-40-18
40 or 42 offset available.
Does that sound about right now? =)
but see for the tyres.. can all 4 of them be 235-40-18?
or do the front ones need to be smaller than the rear? =S
18x7.5 wheels.
- lovemyfto
I have 18x8 215-35-18 on the front and 18x9 235-40-18 on the rears this is the largest tyre comboi I can go without rubbing.
When I bought the Car it had 225-40-18 on the front and 265-40-18 on the rear, I had troubles getting full steering lock which is illegal, they didn't rub anywhere else just at the last couple of degrees turn on the steering wheel.
The rears where another story, they had spacers to make them fit in the wheel well and had the guards rolled...not that this is very usefull in the FTO as there is a big plastic piece on the rear end of the wheel well right next to the bolt/screw that holds the read bumber to the body. thius rubs like a bitch, so rolling guards in my opinion is a waste...but what would I know they where already done for me.
18x9's do fit on the back contrary to popular belief, only by a bee's d__k and you can only go as far as putting 235-40-18's on them.. not the best but again I didn't buy the rims they where on the car when I got them.
LONG STORY SHORT
Front's no bigger than 215-35-18, or they'll rub on the turn
Rears if you rims can tack them, 235-40-18 do fit...
if you want all the wheels the same you need to stick to the post that names all the tire sizes. it's under FTO information. Basically 215-35-18 for you
LONG STORY SHORT
- FTO338
I doubt that he lowed the car, as his got the DC side skirt & its still got heaps of clearence. Its got more clearence then my stock side skirt.
