if not, which year come with projector headlight? anyone selling a set
Thanks a lot
PS.
Low beam on FTO are Projector type, & High beam are Reflector type, so if you want to get a better picture, just look at your own car or next time when you see one (if you don't own a FTO)HiRAEdd wrote: Projector are those like the FTO has. They are totally clear and basically focus the beam, similar to some expensive torches like a "maglite". The beam typically has a well defined cut-off point.
Reflector are like those seen on most cars. The light passes through a "textured" glass or plastic cover that serves to break the light up and spread the light. The beam, whilst if set correctly does not blind drivers, typically has a blurry edge, or atleast lest well defined in comparison to the projector type.
Yep that is so true, but there are lots of ppl out there keep calling HID as Projector LightsHID (High Intensity Discharge) does not refer to the headlight assembly itself, it is simply the bulb (and associated hardware).
