Engine Rework
- Taiwo
Engine Rework
So I finally got myself the mivec engine, have been wanting to replace my GP engine for a while. Is there anything I need to do first before doing a straight swap in and out. I plan on changing the timing belts and getting new seals. What else do I need to do while the engine is out?
Also if there are any mechanics here who want to earn some money helping me out give me a yell
Re: Engine Rework
Timing belt and waterpump. While its out, timing belt coming off anyway so should do cam and crank seals and rear main.
- Taiwo
Re: Engine Rework
There should be no problems with the GPX engine fitting into a GP fto is there? Should I also get timing belt kits and timing belts from autobarn/repco. Their is some extraordinary prices I have been quoted
- SchumieFan
Re: Engine Rework
no its the same motor.
yes you can get your belts from there but buy the kit and you will probably need to wait...
- bjk
- Totes
- Taiwo
Re: Engine Rework
Damn I am pretty sure its a GR now that I look at it. Dont know how I got it wrong this whole time.bjk wrote:Do you mean GP or GR?
Now I am kind of worried as I dont think the GPX engine will fit.
I got quoted $330 for timing belt kit @ repco for a normal one and $550 for one that is supposed to be the next level. Should I just get the ones I see on ebay for $200?
- SchumieFan
Re: Engine Rework
the engines themselves are the same size and mount... you will just need the gpx wiring harness.
im off the next 2 days, let me know if you want me to drop by
- SchumieFan
Re: Engine Rework
and there are differences in the belts for GPX and GR so dont just buy one from ebay and hope for the best.
mivec (gpx/gpvr) motor is 232 tooth and non mivec (gr/gx) is 226 tooth
Re: Engine Rework
You can change the motor to a mivec fairly easily - you need ECU and wiring loom and you're good to go.
- Taiwo
Re: Engine Rework
Cheers schumie. I am working till Friday afternoon unfortunately only weekends I am free. I will reckon I will just get the timing belt kit from repco.SchumieFan wrote:the engines themselves are the same size and mount... you will just need the gpx wiring harness.
I considered that Dan but their was no point when my current engine was on 230 000km with rattling coming from the lifters which means they have to pull the engine out anyway so might as well go slightly cheaper routeDaniel2019 wrote:You can change the motor to a mivec fairly easily - you need ECU and wiring loom and you're good to go.
- bjk
- Totes
Re: Engine Rework
Whaaat.
Oh, Dan isn't taking about actually converting your motor, he means engine swapping like you are doing.
Re: Engine Rework
Aren't you swapping your current GR motor (non mivec) to a GPX engine (mivec)?
- Taiwo
Re: Engine Rework
oh i see. yes i am. i thought it would be a straight swap that i wouldnt need anything but the actual belts and seals. what is the go with the ecu? as in why do i need that?
first time doimg this so it will take me a while to figure
Re: Engine Rework
You need an ECU as they are slightly different (different tunes and pins, one set up for MAP sensor the other MAF, mivec solenoids.. etc)
And a wiring harness as the Mivec one has an extra plug or two, the alternator is 4 pin on the mivec not 2 pin as is on the non mivec (you need an alternator as well) and Mivec uses a MAP sensor, non mivec uses a MAF sensor.
You'll need a new intake pipe too.
- Taiwo
Re: Engine Rework
lol what have i gotten myself into. i thought it would just be that easy straight swap in and out. hey dan can you write me a shoppimg list? e is the best place to get these things?Daniel2019 wrote:You need an ECU as they are slightly different (different tunes and pins, one set up for MAP sensor the other MAF, mivec solenoids.. etc)
Re: Engine Rework
Shopping List:
Take GPX engine back
FIT GR engine
FIT GR engine
- Taiwo
Re: Engine Rework
Lol cheers Matt. GR engine has less HP compared to the GP and I get more kms extra on thissilverGPX wrote:Shopping List:
FIT GR engine
Re: Engine Rework
ECU
Wiring harness including MAP sensor (engine loom only - not front body harness)
Alternator
Intake pipe
I think that's it.. can't remember, has been a while
Alternator
Intake pipe
- Taiwo
Re: Engine Rework
Lol cheers. I am looking at a 4 pin alternator from ebay and ECU"s (although I do get confused when they put automatic transmission ECU) I guess it matters whether it is auto or manual ECU.Daniel2019 wrote:ECU
Alternator
Intake pipe
Also what kind of intake pipe am I looking for?
Re: Engine Rework
Automatic ECU is separate altogether. It has blue pin slots and is under the center of the dash. Completely separate unit to the engines ECU.
Mivec intake pipe with no MAF slot.
