Eyebrow Height
- bjk
- Totes
Eyebrow Height
Okay, so f**ken' Regency need the "Eyebrow Height" which is from the centre of the hub to the tip of the mudguard. I need someone with stock springs to measure for me. Schumie?
Re: Eyebrow Height
If you're having to go away & get this measurement, then make it up. What idiots.
- bjk
- Totes
Re: Eyebrow Height
Haha, this is true. But I don't know how official it needs to be. Maybe I'll get Tim to list it at the same time as he says that the sway bar end link connections are meant to have vertical play.Bennoz wrote:If you're having to go away & get this measurement, then make it up. What idiots.
I'm so pissed that someone put a f**king placard in my glovebox with the tyre details, pinged me on that too. Otherwise they have sh*t all info on the FTO.
Re: Eyebrow Height
Just be thankful you don't have to mount 'Dogs balls' indicators like Tarkus did for VIC Roads
- bjk
- Totes
Re: Eyebrow Height
Do explain?Bennoz wrote:Just be thankful you don't have to mount 'Dogs balls' indicators like Tarkus did for VIC Roads
- SchumieFan
Re: Eyebrow Height
They said his indicators weren't visible enough and he had to put extra ones on...
Also... As said on FB:
37.5cm front
35.5cm rear
Both sprung weight
37.5cm front
35.5cm rear
Both sprung weight
Re: Eyebrow Height
What on earth do they need that measurement for?
And what did they ping you for in regards to the tyres?
- bjk
- Totes
Re: Eyebrow Height
Probably to do with suspension travel/ride height.
Tyres too tall, or the rolling diameter rather is too much over the 15mm extra allowed.
Re: Eyebrow Height
^^^Bennoz wrote:If you're having to go away & get this measurement, then make it up. What idiots.
If they can't be fucked doing it themselves then just bullshit in your favour.. simples.
Re: Eyebrow Height
In SA they determine if your car is too low by measuring hub centre to wheel arch.
They dont measure ground clearance.
My boss got his SS commonhore defected roadside for too low, the cop used the forementioned measurement.
- bjk
- Totes
Re: Eyebrow Height
I think they do both actually. But to be under the 100mm and not under the eye brow would probably mean a really low kit.
Re: Eyebrow Height
....or tiny little rimsbjk wrote:I think they do both actually. But to be under the 100mm and not under the eye brow would probably mean a really low kit.
- bjk
- Totes
Re: Eyebrow Height
Lol, yeah, probably get you for undersize tyres then too!PHIL069 wrote:....or tiny little rimsbjk wrote:I think they do both actually. But to be under the 100mm and not under the eye brow would probably mean a really low kit.
