theres a beeping noise coming from my engine bay i dont exactly know where but its not always on, most of the time when ive stopped and idling i can hear it. the same beeping also starts when i am about to stall and voltmeter drops a bit.
none of the error codes on my cluster are flashing either. is this beeping normal?
beeping noise help
- droz
Re: beeping noise help
I only get a beep in reverse
Complete FTO (http://www.completefto.com.au/completefto.asp) ![Image](http://www.completefto.com.au/assets/contentitems/sig4.jpg)
May be some sort of immobilizer/alarm system I suppose... but yeah usually most cars only beep in reverse unless someone has installed forward facing proximity sensors (basically reversing sensors for the front)
Mine doesn't beep at all in reverse :p
- aza013
- NSW Coordinator
As said it sounds like an alarm problem. Feed back to the alarm siren from an earth leak.
I get it all the time.
