Tie rod ends?
- Herron
Tie rod ends?
Hey, does any one know the part number or specifications for the FTO tie rod ends, any cars which share the same part?
- FTOwnage
Re: Tie rod ends?
ASA is telling me MB912076.
Anyone confirm?
Anyone confirm?
- Herron
Re: Tie rod ends?
MB616023 possibly?
Re: Tie rod ends?
MB912076
- Herron
Re: Tie rod ends?
Are the steering rack ends and tie rod ends the same thing? Im after the boots which go on the end of the steering rack because mine have opened up and will eventually fail.
Re: Tie rod ends?
MB350581 steering rack boots
- Herron
Re: Tie rod ends?
thanks broSahin wrote:MB350581 steering rack boots
Re: Tie rod ends?
Do you mean the larger boots that are over the inner tie rods and rack or the small ones that are on the outer tie rods and connect to the hub?
- Herron
Re: Tie rod ends?
thats an excellent question, I've been discussing this with my mechancic. I'm assuming the part i need is up near the steering rack and not near the wheel hub.Vectose wrote:Do you mean the larger boots that are over the inner tie rods and rack or the small ones that are on the outer tie rods and connect to the hub?
Re: Tie rod ends?
Then yeah that would be your steering rack boots.
If not here are both tie rod ends.
http://www.ebay.com.au/itm/2-OUTER-TIE- ... 27b4d731b1
http://www.ebay.com.au/itm/2-RACK-TIE-R ... 27b4d73134
- payaya
Re: Tie rod ends?
Same as a ce or cc lancer can't remember.
