hi
i have this exhaust light on when the car is idle and basically if my speed is below 55km
if im above 55km cruising that light just goes away and as soon as i slow down again it lights back on
do you know what is wrong with my exhaust ? can anything be done?
thanks
exhaust warning light...
- hnm738
- RallyMad
I would think this light would just be warning you that the cat is hot, as the get during use and not to pull up on dry grass etc. Which may catch on fire. Then again if nobody else is getting this then there must be a problem somewhere causing the exhaust to overheat? I wouldn't know how big of a porblem that would be though
- GWIDO
cat
don't know much about cats, but if it is getting hot there must be something internally wrong unless your motor is running hot, dumping fuel into the exhaust or the cat/exhaust is damaged/restricted causins a backlog of hot gasses.
Could even be the sensor or a loose wire hey?
- RallyMad
