Hello all,
Have I got a weird one for you, I'm looking for a detail ECU pin out/diagram that show four plugs, not three plugs like the one we can download from the Irish site.
I think its the M6A version from the Apexi diagram, which consist of 35pins (section 1) 26pins (section 2) 28pins (section 3) & 30pins (section 4)
Its for a GPX 4 speed tips
This had drive me crazy for a while now, so any help would be much appreciated.
Not your standard 3 plugs ECU pin out/diagram
- FTO338
- smorison
- The Godfather
Re: Not your standard 3 plugs ECU pin out/diagram
which model uses only 3 plugs???? all ECU's i thought had 4FTO338 wrote:Hello all,
- FTO338
Well if you check out all the detail diagram availible on the net they are all 3 plugs.
Check the one in the PDF form for the Chassis number 1 manual, its 3 plugs, you can also get a stand alone one from some other website, its also 3 plugs, on the Apexi website you can see theres few different one of 4 plugs as well, but not in details.
So don't ask me which one its using 3 plugs, cause all i know its i need 4 plugs in details.
- smorison
- The Godfather
yeah my apexi stuff has 4 plugs, never actually looked at that part of the wiring diagrams in the manuals.........FTO338 wrote:Well if you check out all the detail diagram availible on the net they are all 3 plugs.
