Starting issues
Starting issues
When ever I leave my car for a long period unstarted say over 24 hours, it cranks and runs but mostly splutters and coughs and then either gets going normally or stops. Upon restart it goes like nothing is wrong.
Any ideas what's causing this.
- JSP-INC
IDLE speed control motor perhaps, maybe its stuffed like how mine was...
do u have like fluctuating revs at the lights?
on cold start, my car used to start then stall straight away... sometimes splutter at 250rpm then kind of rise to only about 800 where it should be about 1500rpm when it's cold...
it might be the same problem as what i had..
- fto617
- FLY_801
hmmm sounds like it could be the stepper motor. its a common problem. sometimes the stepper motor could be dirty and just needs a clean as it is often neglected. check this article out.
it is really helpful
http://homepage.ntlworld.com/jaycom/fto ... tepper.htm
or it could be the throttle body could be dirty and needs a clean. to clean jus remove the inlet piping and use carburuettor(spelling) clean.
good luck
![Razz :P](./images/smilies/icon_razz.gif)
good luck
- smorison
- The Godfather
- smorison
- The Godfather
- FLY_801
in terms of replacing the stepper motor theres are place called nardek think they are located in frenches forest think the site is www.nardek.com.au they sell the stepper motor for like 280 i remember reading somewhere that the fto uses the same ones as a magna or something but im not certain. Im gona clean my stepper motor as well hoping its just dirty
- smorison
- The Godfather
yeah once the car is warm it should drop to around 750... (sometimes this looks like 500)....fto617 wrote:hey steven
so after u start the car it drops to under 1k its normal?
sometimes i start the car it stalls
do u think its spark plugs prob?
coz i havent replace them yet lol
and its done 110k
dirty plugs
dirty fuel filter
dirty ISC
all these can lead to cars stalling...
has you car had a major service??? how long since its last service??? if you haven't had a major service yet it's seriously time to...i know they can be expensive (especially when done properly) but the cost is a hell of a lot cheaper than a new motor!
- RT
It said that you can clean the stepper motor with WD40..... my question is...do you clean the black tip only? won't it destroy it?FLY_801 wrote:hmmm sounds like it could be the stepper motor. its a common problem. sometimes the stepper motor could be dirty and just needs a clean as it is often neglected. check this article out.
good luck
- FLY_801
well i just cleaned my stepper motor today with it, but i havnt tested my car to see if the idling problems have stopped. Im not a mechanic and like you im just learningIt said that you can clean the stepper motor with WD40..... my question is...do you clean the black tip only? won't it destroy it?
- payaya
- FLY_801
it is also easy to replace by urself..
goto www.nardek.com.au
remove the inlet pipe..
then unscrew the the 2 bolts or whatever.
remove the ecu cable thing.
put in the new one
reset ecu
then wholla i think it should run beautifully again... hehehe
put in the new one
reset ecu
