Rev meter not working, ear shifting...
Bluelite
Post by Bluelite »
Just bought my FTO. But the seller told me: rev meter died...
It's kind of strange to floor the pedal without knowing when to shift. Should I just learn to shift with my ears? :?
What will be the most possible cause of this problem?
How much will it cost to fix it? :twisted:
Thanks!
-Nighthawk-
Re: Rev meter not working, ear shifting...
Post by -Nighthawk- »
Bluelite wrote: Should I just learn to shift with my ears? :?
For now, yes. Just don't play music and you'll be fine. I never look at the rev meter unless I have music up loud, you will learn your engine :P
Bluelite
Post by Bluelite »
As a matter of fact, mine is AT, so daily ear-shift is automatically done by FTO itself.
Only worried about it when I need some extra fun.
Conclusion: "Shift indicator"( I don't know if it's called this name) like the one on civic type R can replace the basic function of rev meter on a AT version car.
After searching the forum, I decide to replace the ignition failure sensor, hope it can revive the rev.
It should fix the problem for you. Thats generally the culprit.
    FTEvolution
    Post by FTEvolution »
    I had that issue on mine, it seems that part of the loom is fouled by the hood release mechanism. I pulled my entire dash apart and ended up moving things about a bit and it's fine now. Re-insulate stuff too.
    Search here for "fto recall" I think, someone put a link to a site detailing all recalls the FTO has had and that is one of them.
    Smooth and sleepy
    Bluelite wrote:Just bought my FTO. But the seller told me: rev meter died...
    Thanks!
    just change when its hit the limiter :twisted:
    nicholas
    Post by nicholas »
    Ignition Failure Sensor is probably the easiest thing to rule out first. Should only cost about $70 delivered and is a 1/2 hour job at most to replace.
    Failing that, time to start investigating things such as that mentioned by FTEvolution, but I would definitely start with the easiest stuff first. I've replaced the IFS on both my FTOs and it fixed the problem both times.
    Resident Asshole.
