5spd tip, 5spd manual and 4spd tips
- Fulltiltorgasm
is there much of a difference between the 4spd and 5spd tips, and how does the 5spd tips compare to 5spd manual ?? im assuming the 5spd tips might be slightly quicker than 4spd ???
- koolio1234
Best to worse for what????koolio1234 wrote:heres the order from best to worse as far as I know.
5 sp manual > 5 sp Tip > 4 sp Tip
Manual is going to be a better choice if you are worried about power, there is estimated about 20-30% power loss in the auto drive train (this is from what I have read on this forum).
The 5spd better than a 4spd? I wouldnt be so sure on that from what i have read the 4spd is stronger box with a lot less problems but even if that wasnt the case if you need to replace the 5spd good luck trying to find one.
Fulltilt, i doubt the 4spd would be slower than the 5spd I actualy think it would be the other way. The 5spd, IMO would have better fuel economy and thats about it.
However i would love to put this to the test so if anyone in my area has a 5spd let me know
- Fulltiltorgasm
