I followed the steps on dwaynes site, got all the bolts but it won't come out.
I think there's a bolt or something where the headlights are coz that's the part that won't budge .. any ideas?
Removing front bar
Have you removed the fog lights. Also fom memory there may be ones under the headlight on the same lip as the ones that are near the wheel, if that makes sense
- rock_it
Re: Removing front bar
Off memory, I think there are 2 bolts there ... They were on my car ... Had to reach up, and could get em out as they were finger tight ... Nathan had to show me how to get to them though ...JOeJOe wrote:I followed the steps on dwaynes site, got all the bolts but it won't come out.
No, you shouldnt need to remove the parkers/foggies, they are bolted to the bar. You will need to unclip them from the loom though. The guide has all bolts that should be there but thats not to say that someone hasnt chucked in a couple of dodgies as well. There are 2 clips that the bar slides into near the outside of the light on each side though. To unclip, just pull bar and it should just pop out on each side. They may be a bit tight if the bar hasnt been removed before.
Good Luck[/quote]
Good Luck[/quote]
