ATTN: DSTOCKS... Parts required
- ft04me
Hey guys.. after going to pedders to get my fto checked out.. they told me i needed Right hand Strut, Lower Arm R/H and R/H Stub Axle
can someone tell me what these parts are..mayb some1 post up pics? so then i know what they look like and how much work is required to replace these? Specially the Stub axle as i've never heard of it!
Hey Dwayne those are the parts i need!.. do u think u can source it out for me?
Mate why did you got to pedders? they suck balls. They have no idea what they are talking about.
OK,
The strut is basically the shock absorber with the large spring in it. Do you know if you have stock shocks or aftermarket. If you have stock shocks, I have one that can be used to replace the one you have.
The stub axle is the bit the wheel bolts to. Also known as the hub.
The Lower arm is the lower suspension arm (triangular bit that attaches to the bottom of the hub. As to how long to replace, you are probably looking at about 30 minutes if you know what you are doing and have the right tools. Can be a bitch to get the hub off as the crown nut is usually bloody tight.
I have all the bits they have told you you need.
- ft04me
yeah my fto is stock as a rock.. only mods are the "custom body" thanks to the guy who crashed into me..lolz so yeah the strut is stock!dstocks wrote:OK,
how long do u think it'lltake til u get these parts? or they they already off and ready to send? are you coming back here again to pick up your furniture?
Auction hasnt ended yet, so dont know. As to how long to get off, about an hour maybe less. Hopefully will try and get it all done on the weekend
tomorrow......
