Welding
Welding
Ok looking at buying a welder and not sure which is the best and easist to use. I have a lot of gas welding expeience but have never used tig or mig. Which would be the best for me do yo think
It needs to be able to be used at home and good for a beginner. It will be used for mainly small exhaust jobs etc
- manofwood
yeah after i wrote that i googled it and i think i'll be going mig
heres one i found on ebay do you think it will be alright for small jobs like my intercooler and exhaust stuff
http://cgi.ebay.com.au/MIG-MAG-WELDER-1 ... dZViewItem
- DaveO
Can you tell me what would be considered as bigDaveO wrote:Buy as big a unit as you can afford. You can allways turn it down but you can't turn it up any higher than flat out.
Cheers
- DaveO
Typicaly the more amps they put out the more they cost.I8A4RE wrote:Can you tell me what would be considered as bigDaveO wrote:Buy as big a unit as you can afford. You can allways turn it down but you can't turn it up any higher than flat out.
Cheers
To weld 5mm plate you need about a 200amp welder. Any smaller and you wont get the heat into it.
So say if you're going to build a trailer then about 200amp welder minimum.
Thanks dave, but yeah im welding steel piping (exhaust thickness), i think its like 1.5mm thick or something like that. However i will start looking at some heavy duty ones and see what the price difference isDaveO wrote:Typicaly the more amps they put out the more they cost.I8A4RE wrote:Can you tell me what would be considered as bigDaveO wrote:Buy as big a unit as you can afford. You can allways turn it down but you can't turn it up any higher than flat out.
Cheers
Cheers Simon
- mr-charisma
Hey mate, was just browsing the Autospeed articles & came across these .. thought you might be interested;
http://autospeed.com/cms/A_108738/article.html
http://autospeed.com/cms/A_108763/article.html
http://autospeed.com/cms/A_108765/article.html
- DaveO
- mr-charisma
- mr-charisma
- mr-charisma
You wont find them at Bunnings. Got to BOC - keep in mind that with all this welding gear, you will need to create an account to hire out all the gas bottles you'll need. For oxy, you'll need Oxygen & Acytelene bottles, for mig you'll need Argon or C02 or a mix - and also keep in mind BOC bottle are rented out on a weekly basis, from memory its about $15 a week rent on a G size cylinder. That may differ from area to area.
- manofwood
whats wrong with arc on exhausts? i never had a problem with them, atleast for little repairs on exhaust cracks and holes etc...
i didnt think about turbo kit before i spoke.
can you even use MIG's on aluminium for the intake setup, or whatever I8A4RE's looking to do? i thought thats what TIG was for? why cant you just buy pre shaped pipes for your intake?
Racing in a VL is like being in the Special Olympics, coz even if you win, you're still a <u>RETARD</u>
Nothing, Im more concerned about technique. Much easier for a Queenslander to point a little nozzle & squeeze a trigger as opposed to starting an arc & controlling a 20+cm rodmanofwood wrote:whats wrong with arc on exhausts? i never had a problem with them, atleast for little repairs on exhaust cracks and holes etc...
Im not a f**ken QLD'er ben
. Isnt living with them punishment enough for being a kiwi
So can mig be used for alloy or not???
- DaveO
YesI8A4RE wrote:Im not a f**ken QLD'er ben. Isnt living with them punishment enough for being a kiwi
But you need differant gas, torch liner and wire and an AC/DC welder (not the rock band). They can be very expensive.
I would recomend buying an AC/DC TIG welder if your going to weld alloy and steel. No liners required, the same gas for steel and alloy and cheaper to by a pack of welding wire.
Plus you can still weld up that trailer of yours.
