fly wheel type: aluminum or Forged Steel?
- tintin
witch would be better? im looking at the aluminum fidanza fly wheel cos its lighter what do people think?
coilovers!! gaurenteed to make boobs bounce
- jonowong
http://www.rpw.com.au/shop/index.php?pa ... &Itemid=31
yeah the aluminium is $335
and the chrome moly is $600
dont ask me why though
- tintin
that will be great if you can let me no what 1 are you getting?Bennoz wrote:The alloy ones are the lighter of the 2. I'll let you know what they are like as Im expecting mine to be delivered today or Monday. The Chrome Moly ones are more of a mid range weight - for those that dont want to loose to much low down torque.
im planning on ordering 1 very soon as well
is low down torque important?
- tintin
i gess the chrome moly 1 would be hard to machine cos its a harder metal?jonowong wrote:http://www.rpw.com.au/shop/index.php?pa ... &Itemid=31
- SG
if chrome moly is like a stainless-steel solid cast then its iron + steel + chromium, way stronger than aluminium because of the iron but its heavier as ya say,... and more brittle because of the steel, so its less flexable (modulus of elesticity) before it snaps.
but ive only heard they snap on bs-high-torque drag engines lol...
best material i've found for car suspension and some other parts (used on high end porsches and the zonda's) is magnesium zk60a if you can put a good enough coating on it to make it flame-proof! ~33% lighter than alu, ~50% less flexable, just as hard, and just as strong, and just way too expensive.........
Getting the alloy one.tintin wrote:that will be great if you can let me no what 1 are you getting?Bennoz wrote:The alloy ones are the lighter of the 2. I'll let you know what they are like as Im expecting mine to be delivered today or Monday. The Chrome Moly ones are more of a mid range weight - for those that dont want to loose to much low down torque.
Low down torque is your call - if you dont mind constantly down shifting to get yourself up a hill, go for it. It'll rev out faster but you loose that low rpm pull.
- tintin
