Air filter
- testlabmonkey
Air filter
Hey guys need a new air filter and was looking at the options.
I've read some good things about the ITG air filters but they dont seem easy to get in Aust. Also there is the UAS setup or something similar with the heat shield which also looks quite neat but at $400 + postage seams a little on the steep side.
Just wondering what the other fto'ers out there think.
Ben
Ben
- testlabmonkey
Unfortunately UAS dont make the pipe anymore. You'd probably be surprised what your local auto shop carries that you could use to make up your own pipe. I've just got 2 x 75mm diametre, 90 degree silicon pipe bends making up mine... purchased from Auto One.
![Image](http://img164.imageshack.us/img164/1571/dsc00501640x480ya4.jpg)
Although from memory, your a GPX, so you wont have the air flow metre in the middle like I do. Just whack a length of 75mm pipe in there or something.
- testlabmonkey
- bushido
I checked with UAS in December (you may have made a more recent enquiry) but they told me they didn't have any more heat shields. They said they'd contact me when they got new stock but I'm still waiting. So i just built my own using aluminium sheets, a few brackets and bolts. Mind you it did take me 5 hours. BTW I'm using the UAS intak pipe and was using their Unifilter. I realised the box I made wasnt too good so i reverted back to the stock box with a K&N panel filter feeding the UAS intake pipe. Pretty good response but I've lost a lot of the knarl. ![Rolling Eyes :roll:](./images/smilies/icon_rolleyes.gif)
- testlabmonkey
- Supplanter
- bushido
Unfortunately yes. I do think that the UAS box isnt all that great. See how you go and try building one yourself. It wont cost you more than $30 and its equally as good( or bad ) as the UAS one. But make sure you plan ahead before you start cutting any sheetmetal. I didnt plan and my box came out wonky and too small.
Testlabmonkey you said in your first post that you need a new airfilter? I'm assuming it's a pod so that's why youre looking for a box? Well have you thought about just using the stock air box and chucking in a panel filter? Then all you would need to do is to change your intake pipe. Just another option![Very Happy :D](./images/smilies/icon_biggrin.gif)
- testlabmonkey
unfortunately i dont have the original box so not an option. as for pod filters restricting air flow i believe simple dyno testing will confirm which filter works best. I will go with the assumption that they are better than the stock paper filter. I have decided to make my own pipe and heat shield using proper heat shielding materials then shove a K&N 3 inch pod on the end.
Heat Shield Material
- bushido
+1khunjeng wrote:dumbest thing I have heard.oodLes wrote:Sorry to go a bit off topic here but a mate of mine is under the impression that pod filters restrict airflow rather than increase it. Any merit to this claim?
Was a 4kw gain on the dyno at UAS for me. Another 4kw gained from swapping out the stock intake pipe - also dyno test before & after.
Also, using the K&N air extreme on the UAS 300Z car, it recorded less than 0.5kw difference on the dyno when the filter was removed completely & it was sucking straight air.
- testlabmonkey
- payaya
I can say with certainty if your POD is not boxed, you will be losing power period. You got to remember dynos is one thing, but in real terms your car does not have a fan constantly blowing on it at a set of traffic lights which means hot air.
Screw the pod, its for the noise, get a decent quality panel filter with a modified intake to your stock air box.
Theres no point spending so much time on your intake 5KW crap all. Remove the spare wheel from your car and floor mats probably do about the same.
But I guess when your chasing times down the quarter mile everything counts!
- payaya
- Delvance
- testlabmonkey
