lightened flywheel
- jonowong
lightened flywheel
whose got one?
hows drivability after one?
i know revs fall faster aswell as climb faster so when your crusing on a highway what happens?
what about hills?
how much faster are you?
is it worth it?
BEN I KNOW U GOT ONE! NO AVOIDING ANSWERING ME!
what about hills?
is it worth it?
- Delvance
- Shahrez
- SG
dont know about losing low down torque
i have one... feels slightly faster but i only noticed the quicker decelleration....
and had to be a bit careful in the carparks and things like that where you only use a little bit of throttle... if you want to go slower you gotta take your foot off in fractions of a millimeter or it goes into decell and your neck snaps forward not so bad if your in second though, or if the air con is on (idle speed is up) its not so bad...
- FtoSam
- manofwood
The flywheel, or flexplate, mounts to the engine's crankshaft and also serves as a mounting location for the torque converter. Consequently, the flywheel or flexplate transmits engine torque to the torque converter housing. The flywheel?s ring gear also serves as an engagement point for the pinion of the starter motor when cranking the engine. Because of the lightweight design of the flywheel or flexplate, it does not help to smooth out power pulses from the engine like the flywheel does on a car with a manual transmission. On cars with automatic transmissions, the torque converter provides this function.
- jonowong
Jonowong wins HA HA. What sound way to clever for me eh?
- khunjeng
- Mitsiman
