Righto...
Just need to know what gearbox does the GS use?? is it the same as the GR and GPX???
What gearbox is in the GS???
- FtoSam
- SG
GS use the 4g93 1.8 and have a 4g93 gearbox...you can get AWD ones of those from a libero/lancer gsr etc... *pats google*
some info here about what gearboxs are compatible....... http://www.mivec.co.nz/forums/viewtopic ... 08&start=0
and here http://www.mivec.co.nz/forums/viewtopic ... b69b5ad985
4G15, 4G92, 4G93, 6A12 and 6A13 all run a F5M421 gearbox
assuming thats true, u jsut gotta check the drive shaft size on the gearbox code... and then anything with F5M42 in it should bolt up, with maybe some slight modification to the bellhousing. i think the starter motor locations vary a bit....The FTO shafts are bigger. My FTO gearbox code is F5M42-2-V7A6 (VN6832) and a typical 4G92 gearbox reads: F5M42-1-xxxx. I guess the 2 and the 1 indicates output shaft size.
