which one is better ? D2 or G4 coilover ?
they got nearly the same price D2( $1300) G4 ($1400 ) , but i dont know which one is better ? D2 got only 1yr warranty , but G4 got 2yrs warranty ..anyone here tried G4 ?how is it ? good for daily driving ? G4 got lower spring rates than D2 .. which one do u guys rekon?
- khunjeng
here is a suggeston since this is about ther 4th post on a similar topic.
Take your car to a good suspension place and have them give u a run down on what is good and what is not. There are plenty more options than this brand. THey will also suggest good spring rates for your needs and suggest things like staybars etc if you really want good setup.
Its a total package.
- aza013
- NSW Coordinator
- Delvance
That just depends on spring rate and damper setting though (well mostly).
G4 and D2 eeh...between the two, i myself would go for G4, as you just buy from justjap and it's 2 years replacement warranty. I think D2 is fix first, then replace if it can't be fixed. a lot of coilovers come out of the same factory anyways or use parts from big brands but assembled somewhere with cheaper labour. It's true for a lot of industries really...
- aza013
- NSW Coordinator
G4 has a 24 point ajustment on them I changed all settings to get a softer ride but still no good.
the two year warranty is great and they do handell verry well so if you can put up with the bumps they are a great setup
also look at sports springs and shocks and add the pillow tops on to them will do the same thing but with a softer ride up to you
- Delvance
Yeah there's a lot of variations in amount of damper settings. But a lot of the parts, you'll probably find, are the same (same manufacturer etc).
You can even get coilovers that are only a slight bit harder than factory suspension, but maybe a waste of money.
I'm thinking coilovers give more lateral rigidity as well compared to shock spring combo, someone correct me if i'm wrong please. Certainly felt like it when my coilovers went in, but could've been my old suspension just generally being old and stuffed too.
- bonker
Ive been doing my homework and i took my car to the mechanics to get my breaks changed. Mechanic advised me to get my shocks changed as he was feeling the tyres with his hands saying that the tyres were not smooth and had bumps on it which resulted in the shocks not behaving the way it should. He suggested monroe shocks because of our poor bumpy roads in sydney. Which i doubt they have monroe for fto, i take look at rpw kyb excel range. Not too sure if i should get that but its quite cheap and its gas shocks. Front is around 230 and back is 170. I assume koni would be double that price so i decided to look in ebay. I found d2 full suspension kit for front and back for 995. Sounds like a deal and brand new what u guys rekon? Im looking for a smooth non-bumpy drive not for street racing or doing fast turn because i think fto corners awesome compared to all other cars ive driven.
Kind regards
Kind regards
- frozenwaffles
- manofwood
Go to rated r group at silverwater for a full set of TEIN coilovers jap spec for $1600, sh*ts all over d2 and g4, japan quality not brit built taiwan assembled crap.
i just did a driving course at oran park and beat a 200sx with 220kw at the wheels (and a 12.6 1/4 mile) in slalom stage by over a second, and that was only with the front coilovers installed!
- BorepYano
they r built for perfectly smooth rd, not what we have here, end up boucing around on our crappy rds
suppose it wont matter on the track much (u'd hope at least the tracks here are smooth)
- manofwood
- Delvance
Jap spec teins on a track should outperform aus spec teins??!!! No way would it be a time loss... The aus spec ones are more geared towards comfort than performance.
I ran jap spec teins (type HA) on my car for almost a year and i loved them. Easily beating a supra in touge in RNP and slightly bettering a wrx with sti spring/shock setup and i don't even have an lsd.
I suppose it comes down to how you like your car though...i tried to make my car more raw by removing weight, beefing sound up and ran the jap teins. Awesome driving experience for me (my best mate loved it too but thought the suspension was just a tad hard).
Goodstuff manofwood!! Show those turbos in the curves!
Aussie tracks are like Aussie roads. sh*t compared to the rest of the world.
If your setup is too hard (even on the softest setting) the strut assembly will be pushed up by a bump & it will come down too fast - usually before the bump is over. This leads to a loss of traction, the tyre will skip, drop then slide.
This info ^^ I get is from guys who run on tracks regularly, not street racers. If unsure have a word to Fulcrum Suspension in QLD, they are the only authorised Tein rebuilder in Aus. They get over a dozen sets of Teins for various makes & models in a week to be respeced from Jap to Aus. Typically the damper & rebound settings range is relaxed.
Driving style can have an effect yes, but your style needs to adapt to be the quickest on a track, not to adapt to the suspension.
- Delvance
Makes me not wanna visit our tracks after reading that
I knew our roads aren't up there with the best...but they could've made the track decent =/.
Yes, my best mate commented the arse on my fto hopped a bit during touge runs in RNP but i kinda liked it myself, gave the car character and brought more driving enjoyment. Driving's just so personal though...each to their own. But back then i would've thought jap spec would've produced better times. Well regardless, bettering a turbo 4wd with sti sussy setup was already pretty satisfying for me.
For on the road driving, i'm sure everyone uses a different style than on the track (or mostly), but yeah i agree on the track, the car should definitely be set up to connect with the driver, not the other way around. But then again, how do you define style ?!
