Jono's TURBO Research, Questions and possible Application!
- jonowong
http://www.mscn.com.au/
where to get TD04L oil feed line...
i think the size is M12x1.25 not too sure atm
- jonowong
http://forums.nicoclub.com/zerothread?id=113767
greddy wiring information and tuning interface images and examples
http://forums.nicoclub.com/zerothread?id=157092
DIY greddy emanage tuning
http://forums.miataturbo.net/showthread.php?t=581
emanage info for miata turbos
- FtoSam
I was advised against the Greddy by several different tuners (most of which were only quoteing to do tuning (not supply the unit) and were all qualified to tune them...)
Apparently you get what you pay for, but im very happy with my Microtec LT-10. Will only stall once a month or so. Barely even notice it doing its thing... and everyone will tune them... and tune them better aparently...
Worked out about $2500 from my tuner for:
Microtec LT10 ECU
Tuning (3 seperate tunes)
Fixing some wiring
Supply and fit Walbro fuel pump
Not too bad i spose... Nice guy and would go to him again...
Microtec LT10 ECU
Fixing some wiring
![Image](http://i106.photobucket.com/albums/m264/ftosam/Sig2.jpg)
- FtoSam
- FtoSam
I had very little dramas with mine as well... Only ones i had were errors on behalf of my dodge arse mechanic and now engine problems..
I think the biggest thing is the engine being able to handle it...
Would heavily consider a rebuild at the same time...
Other wise you could end up with a smokey engine...
Or if you dont have a vented catch can, you could loose your dipstick and have a messy engine bay...
My engine only has around 80-90,000kms on it and has recieved tip top treatment ever since i had it put in... and it still only lasted a month or so on 5 psi before ring probs...
Reco the engine... can only be a good thing....
PS. yours GPX or GR?
- jonowong
mine is a GPX... sh*t only last 1 month :s on 5psi... your scarying me away from turboing cos i sure as hell dont want to do a rebuildFtoSam wrote:I had very little dramas with mine as well... Only ones i had were errors on behalf of my dodge arse mechanic and now engine problems..
- khunjeng
the TUNE is the most critial part of this process. If its sh*t, too lean, has too much ping etc your engine will not last long.jonowong wrote:mine is a GPX... sh*t only last 1 month :s on 5psi... your scarying me away from turboing cos i sure as hell dont want to do a rebuildFtoSam wrote:I had very little dramas with mine as well... Only ones i had were errors on behalf of my dodge arse mechanic and now engine problems..
- khunjeng
Croydon will do it. My guys in Vic will.jonowong wrote:yeah ive rang around and theres a lack of tuners... or should i say none... willing to tune a turbo'd fto with ANY ecu
Just run an emanage and its not that hard. To lazy tuning RB25s with PFCs.
I could tune the emange, its not that hard to get an OK tune but I wouldnt trust mine.
- jonowong
- khunjeng
Yeah dunno who u have been talking to.
Most tuners will be down with it as they know its not that hard using a piggy back style system.
U might be talking to mechanics, not tuners. Usually a good tune house will do it all.
Most places will jump at the thought of custom work cos it equals dollars and is more intresting.
- jonowong
lols i might take you up on that offer...khunjeng wrote:Croydon will do it. My guys in Vic will.jonowong wrote:yeah ive rang around and theres a lack of tuners... or should i say none... willing to tune a turbo'd fto with ANY ecu
do u have the software and cable?
- khunjeng
the tuners will have the software u dont need to come down here as per KDs post.jonowong wrote:lols i might take you up on that offer...khunjeng wrote:Croydon will do it. My guys in Vic will.jonowong wrote:yeah ive rang around and theres a lack of tuners... or should i say none... willing to tune a turbo'd fto with ANY ecu
Piggybacks, emanage, safc are easy to tune. anyone who says they cant is lazy or full of sh*t. If they can tune a PFC or Microtech than can any of these easily.I have looked at the map software and is pretty easy to follow.
Word of advice. fine a good place and get it done there. Dont bother doing any research until u have found a good place and BTW they willl tell u what to do anyway. Once u really get into the turbo setups...its quite complicated.
Ask KD he knows.
It's not so much being able to tune a piggyback KJ, I reckon one problem is that not all tuners will have access to the Support Tool software needed to tune the emanage. I don't reckon it's half as widely used as something like the Apexi S-AFC (which doesn't have the features of the emanage, but it can be tuned off the unit which is one reason they are so popular).
Jono you'll just have to do the call around and if they can tune an emanage.. I do know that CRD have it though. If you have any problems finding a tuner let me know and I'll get you some more names.
- jonowong
that destroys the DIY!!!
anyway heres some info on the turbo im using
![Image](http://www.wallpaperinstaller.com/scooby/13T.jpg)
FTO running on 4psi
(4psi + 14.7psi)/14.7psi = p/r (pressure ratio)
18.7psi/14.7psi = p/r (pressure ratio)
1.272 = p/r (pressure ratio)
pressure at the compressor outlet (Pco)
Pco = 4psi +1psi + 14.7psi (fto running 4psi with 1psi pressure drop from intercooler)
Pco = 19.7psi
after density after intercooler (Di)
Di = (Boost + Atmospheric Pressure) / (R*12*(460 + Post Intercooler Temp))
Di = (4psi + 14.7psi) / (53.3*12*(460+130°F))
Di = (18.7psi) / (53.3*12*(590R))
Di = (18.7psi) / (377,364)
Di = 4.95542 x 10-5 pounds per cubic inch
mass flow, fto at 8000rpm
ve = volumetric efficiency
Mf = (Di * Displacement in cu. in. * rpm) / (2 * VE)
Mf = (4.95542 x 10-5 * 122 * 8000) / (2 * 0.![Cool 8)](./images/smilies/icon_cool.gif)
Mf = (38.36497) / (1.6)
Mf = 30.2281 lb/min
corrected mass flow
CMf = (Mf * (square root of (compressor inlet temp in R / 545R))) / (atmospheric pressure / compressor inlet pressure)
CMf = (30.2281 * (sqrt (545R/545R))) / (14.7psi / 13.95psi (due to pressure drop of air filter))
CMf = (30.2281 * (1)) / (1.054)
CMf = 28.6794 lb/min
and the TD04L will be out of efficiency before i even know it![Sad :(](./images/smilies/icon_sad.gif)
FTO running on 4psi
Pco = 19.7psi
Mf = 30.2281 lb/min
corrected mass flow
