Thanks man appreciate itAstron_Boy wrote:I will concede, your Supra does look good.
Okay guys i brought a White 1995 Sz-r Supra !!!
- King hit kiz
Re: Okay guys i brought a White 1995 Sz-r Supra !!!
- King hit kiz
Did the LED a/c conversion today, everything turned out really well except for when I put it all back in relised I used the wrong resistor on the top led strip and some smoke action happened and then they shorted... Will fix it up another day....
Also love the new buttons
Also did my clock and odo
Lights off:
Lights on:
Lights off:
Lights on:
- King hit kiz
- King hit kiz
So I put a order for my parts for the engine, Basically did every single 100km serviceable item bar the coilpacks as I don't have $550 spare at the moment lol
Heres my list
Flywheel bolts - 8
tensioner Bolts - 2
Timing belt tensioner - 1
Crank Seal - 1
Coilpack Connectors - 6
Washer for rocket cover - 16
Rocket cover exhuast side - 1
Rocket cover intake side - 1
Oi filter - 1-
Thermostat - 1
Timing belt cover 2 - 1
Timing belt cover 1 - 1
V Belt -
Damper Bracket - 1
Damper bracket - 1
Rocket cover bolts - 12
Rocket cover nuts - 4
Fuel Filter - 1
Harmonic Balancer - 1
V belt Tensioner - 1
Tensensior bolts - 2
Tensenior bolts - 2
Tensenior bolts - 2
Tensenior bolts - 1
Tensioner bolts - 1
Tensioner bolts - 1
Tensioner assembly - 1
Tensenior bolts - 2
Spark plugs - 6
Spar plug boot - 6
crankcase front hose - 1
Crancase back hose - 1
Radiator Hose in - 1
Radiator hose out - 1
Cam seals - 2
Rear main seal - 1
Timing belt cover bolts - 16
Total cost including shipping 1G !
Still need to order a water pump and V belt absorber but think that's everything
Also done my heater core over the past two days, and boy what a job ! Nearly done just some finishing touches but good to have a car that looks like one again
Heres my list
Flywheel bolts - 8
tensioner Bolts - 2
Crank Seal - 1
Oi filter - 1-
Thermostat - 1
V Belt -
Damper Bracket - 1
Damper bracket - 1
Fuel Filter - 1
Tensenior bolts - 2
Tensenior bolts - 2
Tensenior bolts - 1
Tensioner bolts - 1
Tensioner bolts - 1
Tensenior bolts - 2
Spark plugs - 6
Spar plug boot - 6
Cam seals - 2
Rear main seal - 1
- King hit kiz
Looks like a scissor jack could fit in that spot.
- King hit kiz
Cheers for the reply, But nar everyone says that lol
Scissor jack is on the other side, was maybe thinking a flare ?
Supra people don't know what goes in a Supras boot?
Already has a scissor jack, so not that...
Meanwhile, nice effort on the interior, looks as bad as the Mercedes behind the dash.
- King hit kiz
Astron_Boy wrote:Supra people don't know what goes in a Supras boot?
They sure do except for that spot ? Everyone else seems to have that spot blanked that has had a guess ?
Cheers man, Interior is nearly complete just a few more things till it's done. Dash needs a good 2 pac paint job lol
So what's the deal with the new motor? Turbo?
looks good though!
looks good though!
- King hit kiz
Yeah new motor is a 2jz-gte where as mine is a 2jz-ge and yeah its turbo
Cheers man so keen only a couple of weeks to go already had a big pile of parts arrive
- King hit kiz
wow, lots of stuff!
and yay for turbo
and yay for turbo
