The Suspension Thread
Re: The Suspension Thread
Pretty sure you just use normal smaller ones...
But I bet yours are fine and are able to be used
http://www.ebay.com.au/itm/2-FRONT-Sway ... 2c1&_uhb=1
That's the one I can see on ebay. And mine are farked, both front and rear...I can move the joints around with my hand everywhere.
Yeah they are the ones man you don't need adjustable ones... They are the ones matt has...
Use standard on the front, lowered on the rear.
I have lowered on rear. But the sway bar doesn't work anyways cos the mounts still f**ken snapped
Soooo, you could say you have a loose rear end?
Thanks, :)
ordered those standard ones from ebay and adjustable ones for the rear:
http://www.nolathane.com.au/product_det ... mber=42733 $90 by price matching through Repco.
Let me dig Shaine's post on what mods he did to the stock rear sway bar mounts to use them with the Whiteline's bar.
Matt has shanes whiteline bar... just have a look at matts
from memory he just drilled another hole and tapped a thread into it and used another bolt on the stock mounts
I'll come over and have a look..
Matt/Sahin either of you coming to GC anytime soon? :|
Nope, not now since I started work. I offered help previously :lol:
How much do you have left to do?
Don't need any help with the car...just want to see the sway bar mounts so I can copy them and grab a beer. :)
shadowarrior wrote:
ZFL45H1 wrote:Im running normal seems ok havent got any problems
Have you lowered your car with the BC coil overs? Normal ones from ebay?
Yes a lot well as nuch as I can till scrubing occurs and yep from ebay like $50 or something like that
Just as an FYI. If you have a Version R, the poly front sway bar bushes don't fit.
Rears also sit a bit loose.
MaxD
Post by MaxD »
Has anyone fitted a Cusco lower front strut brace? I've seen the Whiteline one, but the fixings are slightly different in design.
MaxD wrote:Has anyone fitted a Cusco lower front strut brace? I've seen the Whiteline one, but the fixings are slightly different in design.
You mean sway bars? NOT ultra racing.
viewtopic.php?f=1&t=27625&hilit=ultra+racing
MaxD
Post by MaxD »
Not Ultra Racing, Cusco.
Sway bar = anti-roll bar in the UK (but not this)
I'm specifically referring to the lower front strut brace. I have a the standard GPvR upper front and rear braces and a rear lower strut brace. I've been offered a lower front strut brace but the seller states the fittings are missing. Without seeing one fitted, I have no idea of the fittings required in terms of where they go and what they are.
I am not quite sure I know what you mean by lower strut braces... do you have pics?
MaxD
Post by MaxD »
Lower Rear Strut Brace - Cusco:
No idea on brand, but I have this type in black:
Lower Front Strut Brace - Cusco:
