Got the motor back in the Legacy last night, and it started first try, with the new gearbox and hydraulic clutch :D
Started on removing the Diff, but it got too late last night, so shall hopefully get the new one installed tonight :)
MaxD
Post by MaxD »
Picked up a newer fuel tank earlier as found mine had several holes in it. It would explain the fuel economy and smell of fuel at fill-up. The rust was rather thick and only spotted it as removing all the rust from the car.
MaxD wrote:Picked up a newer fuel tank earlier as found mine had several holes in it. It would explain the fuel economy and smell of fuel at fill-up. The rust was rather thick and only spotted it as removing all the rust from the car.
The rust there is so bad you get holes in your fuel tank? 8O
Doesn't surprise me, he's over in the UK...
Scorpionwally8
Post by Scorpionwally8 »
Doing a few cosmetic touch ups while the car is garaged
mezje
Post by mezje »
Almost 300th page :O
Drained all the oil, replaced filter and refilled with Penrite 10W40
fraz91
Hair-do
Post by fraz91 »
On the cruiser - Removed intake, cleaned intake, refitted intake. C*** of a job and then some, whole fuel system and EGR has to come out to get the manifolds off. But it's clean now and running better than ever!
Audi - Changed plugs and leads, no more misses at idle or dead-spots through the rev's. Tacho still has a mind of its own sometimes though :scratch:
Installed a window closer/opener on the Vajero.
Waved goodbye to it.
Supplanter wrote:Waved goodbye to it.
Nooo Clapping Man, nooooooooo
Vectose wrote: Vajero.
Put all the bolts in the bellhousing (knocked my table that had them all sitting in order so was a bit fun finding which bolts went where lol)
Installed slave cylinder
Installed shifter bracket
Test fitted parker globe holders I bought off eBay in the facelift headlights And they don't fit. The ones off my 121 fit for so might trawl the wreckers for some.
Started prepping replacement sump to replace my dented leaky one, will probably knock over the sump this week
After all that's done I'll get dad to degas my aircon so I can replace my heatercore.
Oh and replaced all the globes in the cluster on the Evo
I spent all weekend working on the Hilux...
1. Fixed drivers door - It was not lined up and was letting wind/water in
2. Replaced both engine mounts - LHS mount was split into 2 8O
3. Replaced gearbox mount
4. Replaced headlights - Upgraded from sealed beams to glass lenses with H4 globes - had to remove bull bar to get it done
5. Replaced front corner parker/indicator lights and globes
6. Replaced tail lights and globes
7. Replaced brake/clutch pedal rubbers
8. Replaced guard mounted radio arial
9. Installed new 1DIN JVC head unit with bluetooth and hands free
10. Installed new 4" speakers in dash
11. Installed new seat covers
12. Installed new floor matts
13. Repaired wiper washers
14. Repaired battery hold down
15. Repaired under engine stone guard
16. Greased all grease points
17. Detailed interior
18. Removed all unnecessary/unused wiring from interior and engine bay.
PHIL069 wrote:12. Installed new floor matts
:creepymatt:
Scorpionwally8
Started cleaning and painting my calibers on my fto
:creepymatt:
f**k'n lol. :lol:
Page 300! \o/
Tim's been working on my car. :lol:
PHIL069 wrote:I spent all weekend working on the Hilux...
Hate working on a hilux dunno if I do too many of them I do or if it's just a c**t.
Scorpionwally8
Been painting my calibers and rims
