silverGPXs Ride
getonit
Re: silverGPXs Ride
Post by getonit »
silverGPX wrote:Well had a wheel alignment - steering is feeling great now.
Replaced two coilpacks that were giving me a misfire, had to test resistance to find which ones.
Just chasing a new stepper motor, where is the best place to buy them? There's a lot of different ones on aliexpress and ebay - not sure which one..
I bought this one recently. Works fine.
Look at this on eBay http://www.ebay.com/itm/321976138484
Sent from my F3115 using Tapatalk
Re: silverGPXs Ride
Awesome that's great thanks!
Re: silverGPXs Ride
Clutch master has now been changed, bled and adjusted.
What a c**t under the dash.
Well worth it though.
Re: silverGPXs Ride
bjk wrote:What plug did you end up using for the parkers? I need to get around to sorting that out, but after swapping headlights I've only got one of the plugs in and the other has gone awol
Also FYI prefacelift Parker bulb holders fit which is what I've gone with now.
Re: silverGPXs Ride
Sweet. I managed to track down the other one of mine, I suspect that's what they are anyway. Still haven't gotten them wired up, lol.
Re: silverGPXs Ride
What cheap copper plugs can I run? I don’t care about taking the manifold off.
Re: silverGPXs Ride
BKR7E
Re: silverGPXs Ride
Vectose wrote:BKR7E
Thanks I appreciate it, I assume you've gone through a lot of these with tuning?
Do you know where to get leads cheap?
I'm trying to sort a slight misfire under load (low rpm 2nd gear)
Re: silverGPXs Ride
Hey Jim,
Just thought I’d let you know that this stepper Mitsubishi number doesn’t match the FTO, in-case you are still having idling issues.
Re: silverGPXs Ride
Well seems FTO is going okay now.
Everything actually works! except for a slight erratic idle.
Wheel alignment shop found out that my rear toe adjustment nuts were chewed out and replaced them for me, the toe used to just wander about previously so that's sorted and the car feels a lot more planted.
I'm not sure what the plan is for it now, I'd rather rack up 500kms a week in the FTO than the EVO, but im only getting 500kms to a tank in the FTO...
One car has gotta go - also new house better garage :twisted:
Re: silverGPXs Ride
Definitely sell EVO while the market is strong, you’d be cutting your losses selling the FTO and someone will f**k it.
My ZR6 Aurion goes through a quarter of a tank a day, just have to live with it. Or buy a Cube lol
Re: silverGPXs Ride
Sahin wrote: ↑Fri Dec 01, 2017 11:28 am Definitely sell EVO while the market is strong, you’d be cutting your losses selling the FTO and someone will f**k it.
Yeah the EVO does seem to hold its value at the moment, I will need to do some light servicing and refurbish the wing if I sell it.
Lol I read reviews on cube they say that it has really bad wind noise on the highway and no seat bolsters so u just slide around lol.
Re: silverGPXs Ride
silverGPX wrote: ↑Fri Dec 01, 2017 11:47 am
Shane-o drives an Aurion :lol:
Re: silverGPXs Ride
Cubes have less noise on the road than fto’s Those 22 year old seals suck lol
For the time I had a cube it was fine and you can’t go fast enough to slide around lol
Re: silverGPXs Ride
Any ideas on how to bring the wiper motor up to oe spec?
Even on 2 it’s slow as...
Re: silverGPXs Ride
Just use Rain-X
Re: silverGPXs Ride
Popped a tyre this morning.
Swapping out fronts for some High performance Winruns :lol:
Re: silverGPXs Ride
Zoom right in on that lock nut for us!
Re: silverGPXs Ride
Sahin wrote: ↑Fri Apr 20, 2018 2:37 pm Zoom right in on that lock nut for us!
LOL!
Do you reckon it was Tawhare that stole the wheels? lol
Re: silverGPXs Ride
Probably to be honest, didn’t occur to me at the time but I smashed his windscreen later lol
