Nah, I saw it... Just kills me... And had that pic on standby for a while now.. Just thought I would get it out thurr...bjk wrote:You obviously missed the joke earlier.![]()
For reference: http://ftoaustralia.com/v3/viewtopic.ph ... se#p375903
Daniel's Rookie DIY FTO Build!
- rock_it
Re: Daniel's Rookie DIY FTO Build!
Hoooooorrrraaaaayyyyyyyy
- SchumieFan
rock_it wrote:Nah, I saw it... Just kills me... And had that pic on standby for a while now.. Just thought I would get it out thurr...bjk wrote:You obviously missed the joke earlier.![]()
Driveshafts in, tie rods replaced, gear selector cables + bracket in...
Seems to be all good. Just have to fix up heater hoses to firewall, connect battery, intake and some vacuum lines.
Question though, it doesn't seem to be getting very much oil up in the heads..? Seems kinda weak. Is this normal or is there something wrong, and if so what could it be? Martin suggested blocked oil lines...
Vague question is vague.Daniel2019 wrote:it doesn't seem to be getting very much oil up in the heads..? Seems kinda weak. Is this normal or is there something wrong, and if so what could it be? Martin suggested blocked oil lines...
The oil spurting into the heads is fairly weak and there isn't much getting up there, seems like there should be moar.
Does this mean you found the fuel pump issue? (sorry im a bit slow)
Yep! Immobilizer
Just ripped it all out.
Also forgot to add - doesn't have an oil light.
As in doesn't have one at all or light isn't turning on?Daniel2019 wrote:Also forgot to add - doesn't have an oil light.
Isn't turning on*
- SchumieFan
yeah it looks fairly dry when you open the oil cap... there is a light 'spit coming through the oil cap but its hardly noteworthy...
i dont expect oil to be gushing out but i did expect a bit more than that...
It's not meant to I don't think.. I've run a car with no rocker cover on and it doesn't throw much oil around lol
- SchumieFan
just checked on tweety... oil 'spit' looks much the same, though the cams are covered in oil, im thinking it may just be cause the cams are 'new' and the oil is new its just so clean and runs straight off... from memory there is quite a few oil galleries along each cam shaft
im 90% sure its perfectly fine and after 100k's the oil will get dirty and it will look more 'normal'
yeah exactly sahin... from memory the oil pressure only goes nuts when mivec hits
- SchumieFan
we're just paranoid about everything on this car as its been a constant struggle/ learning curve
That and if it explodes or seizes then I'm about 8 grand in the shitter
Who says you're not 8 grand in the shitter already?Daniel2019 wrote:That and if it explodes or seizes then I'm about 8 grand in the shitter
Sensor for that is on the oil pump, down low on the drivers side, right in the middle of PS - A/C belt circuit, there's a single blade connector on the pump.Daniel2019 wrote:Isn't turning on*
Doesn't it have warranty?
