Daniel's Rookie DIY FTO Build!
Re: Daniel's Rookie DIY FTO Build!
Sounds like yangs lol
I pulled the one out of yangs and it was easy as an only had black wires coming out of it
Take the steering cowel off and the panel under the dash and the plug that plugs into the ignition barrel is where they would have imobilised it
Just cut it out and rejoin the factory wires, it's really not that hard...
These ones yes?
I don't like touching wiring unless I know what's what
Get rid of the black wires and rejoin the factory ones to each other. Simples.
Alrighty then!Vectose wrote:Get rid of the black wires and rejoin the factory ones to each other. Simples.
Nek minut
- SchumieFan
That's the wiring on the floor of the foot well... The ignition wiring is up near the steering column... Can't miss it, has sh*t loads of bad soldering and electrical tape hanging off it...
If anyone knows what that black/blue cable is I'd be grateful as the immobilizer is spliced into it
I didn't even use a multimeter or anything and I pulled out 2 alarms and re installed another one into my car lol
So then what the f**k did I just take a picture of?SchumieFan wrote:That's the wiring on the floor of the foot well... The ignition wiring is up near the steering column... Can't miss it, has sh*t loads of bad soldering and electrical tape hanging off it...
Surely that one would be fuel then if the other one is for the ingition?
It has to be fuel, Martin!
Retrace all black wires from the alarm. Disconnect them and rejoin all factory wires. Then install a better alarm later on.
That's the planVectose wrote:Retrace all black wires from the alarm. Disconnect them and rejoin all factory wires. Then install a better alarm later on.
Mmmm... remote start
Hey look, the electrical manual! Where did I find that that I wonder!
http://www.ftoaustralia.com/downloads/e ... manual.zip
I have it, downloaded it last night
Let me save you the
3mm, Black with Blue trace for fuel pump? You're welcome
That's what schumie asked
Definitely bringing extra beer to the bonfire
And what you took a pic of. Join it!Daniel2019 wrote:That's what schumie asked
- SchumieFan
Cheers ben, I figured that was the fuel pump wire, but I couldn't find it in the electrical manual...
I joined those wired back together last night with the immobilizer still connected and it still didn't start...
Oh well, will try again tonight I guess
Did you get fuel to the rail though? The other circuit immobilized must be the ignition cirucit.SchumieFan wrote:I joined those wired back together last night with the immobilizer still connected and it still didn't start...
Need to trace up to the ignition barrel..
- SchumieFan
The ignition works because the car turns over,
Fuel is not getting to the rails, took the fuel lines off and cranked the car, no fuel came out the hoses.
Doesn't seem like the fuel pump is running, I took the cover off (after replacing the pump) and did the Ol screwdriver - to the ear test and couldn't hear the pump running...
Got me stuffed mate
Got me stuffed mate
- SchumieFan
Now I know that's the wire though, I can trace it to the relay now, which should be under where the stereo goes, yet I couldn't find it last night
Yeah it has to be that black/blue wire set that Ben said. Those are the spliced ones.
Have been out christmas shopping all day and working on silver car but will have a crack when Martin gets here.
PM sent Bestie
