Well, it depends. I won't be doing it straight away certainly, so in the meantime I'll probably enquire as to the cost of getting new brackets fabbed up. If that's as expensive as Tim reckons then I'll likely buy a new kit.kiz wrote:Would it not be easier just to source stuff for your existing brake setup, rather than trying to sell the old ones and buy new ones?
ATTKD Big brake kit - Just Jap
- bjk
- Totes
Re: ATTKD Big brake kit - Just Jap
- shadowarrior
- Tightarse
Fark me!
Was searching around to replace my rotors...thought of doing the Brembo/GTO upgrades..and I see my name plastered all over the posts!
- bjk
- Totes
Shoulda got this kit when it was first mentioned. Fuckin' Aussie dollar going down the shitter. Now it starts at $1800.
- FTOwnage
Vectose wrote:I think I win on caliper to spoke clearance.
Still need to sand the lettering down a bit as it's still touching a bit as it goes round.
BTW..... GTO brakes without caliper brackets.
- bjk
- Totes
If I'm to get more used stuff I'll stick with the Brembos already on there. Might get another set of brackets fabbed and see if they can give me a bit more barrel clearance too lol
If you've got Brembos, just use Evo hubs. Fabricated brackets can EAD
- bjk
- Totes
I wish.Bennoz wrote:If you've got Brembos, just use Evo hubs. Fabricated brackets can EAD
STi Brembos.
Sell em. Get real ones.
- bjk
- Totes
This is all in that fancy DIY guinea pig you did a while back, yeah?Bennoz wrote:Sell em. Get real ones.
So I just need hubs, calipers and rotors? And that thing done to the bushes?
Or GTO hubs/brakes......
- bjk
- Totes
What actual fiddling did you have to do? Is it literally just hubs and calipers?Vectose wrote:Or GTO hubs/brakes......
Need new outer CVs, and have to get a machinist to take a bit of material off the knuckle where it joins to the shock.
- bjk
- Totes
What's different about the CVs?Vectose wrote:Need new outer CVs, and have to get a machinist to take a bit of material off the knuckle where it joins to the shock.
And hey Ben, have you yet had to order wheel bearings for the Evo V hubs? said they were expensive in your big brake thread.
FTO ones are 25 spline outer, GTO hubs are 27 spline.bjk wrote:What's different about the CVs?Vectose wrote:Need new outer CVs, and have to get a machinist to take a bit of material off the knuckle where it joins to the shock.
- bjk
- Totes
Ah, but it all just fits together with the FTO inner CV? What size rotor?Vectose wrote:FTO ones are 25 spline outer, GTO hubs are 27 spline.bjk wrote:What's different about the CVs?Vectose wrote:Need new outer CVs, and have to get a machinist to take a bit of material off the knuckle where it joins to the shock.
Don't need to touch the inner CVs, just need to replace the outers.
Depends if you get Gen 1 or Gen 2 GTO brakes/hubs.
Gen 1 are 297mm, Gen 2 are 313mm I believe.
Re read the thread. I ended up finding them for about 50 bucks a pop lol. Common to a bunch of really sh*t Mitsiesbjk wrote:What's different about the CVs?Vectose wrote:Need new outer CVs, and have to get a machinist to take a bit of material off the knuckle where it joins to the shock.
- bjk
- Totes
You got the Gen 1 then? Did you reco them as well?Vectose wrote:Don't need to touch the inner CVs, just need to replace the outers.
Well then.Bennoz wrote:Re read the thread. I ended up finding them for about 50 bucks a pop lol. Common to a bunch of really sh*t Mitsiesbjk wrote:What's different about the CVs?Vectose wrote:Need new outer CVs, and have to get a machinist to take a bit of material off the knuckle where it joins to the shock.
Yeah, I've got the Gen 1, only differences are calipers and discs.
Calipers on the Gen 2 have longer arms to space the caliper further out for the larger disc, hubs are the same.
Yup, rebuilt them. Got rebuild kits from rock auto.
