Fans.
Re: Fans.
:facepalm:
c0n13oX
Re: Fans.
Post by c0n13oX »
When are the fans supposed to come on?
-Nighthawk-
Re: Fans.
Post by -Nighthawk- »
Smaller one is meant to be on as soon as you start the car. The larger ones kicks in when you start driving.
Re: Fans.
Ummm... not.. really.. runs off temp.
Re: Fans.
Daniel2019 wrote:Ummm... not.. really.. runs off temp.
That is what I thought... But wasn't sure...
Re: Fans.
Yeah they shouldn't run as soon as you start the car
Re: Fans.
When the coolant temp hits 94 degrees C.
Re: Fans.
SchumieFan wrote:Yeah they shouldn't run as soon as you start the car
...unless your AC is turned on.
The small fan will run if you have AC turned on, it will also run if the engine gets too hot and the ECU decides to use both fans to cool the coolant.
