Just saying Hello!
WoohYeahJunior
Re: Just saying Hello!
Post by WoohYeahJunior »
Same here! HaHa so if I get pulled over I'm pretty much screwed? Good Times! HaH
Ive been pulled over a few times even with a carbon wrapped bonnet and nobody has asked me to open it.
Just pass the attitude test and you'll be right.
WoohYeahJunior
Alrighty sounds good! HaHa
Hey Daniel! How hard is it to apply carbon fibre wrap? Because I want to wrap my centre console.
Dunno, I didn't wrap it. Previous owner (rock_it) had it done by Carbon Demon.
WoohYeahJunior
Oh okay! I'll have an attempt anyway HaHa
Youll need a heat gun.Buy good quality Vinyl and make sure you clean the plastic properly before applying. The plastic has quitea bit of oilin it and youll need to get rid of as much as possible off the surface before it goes on.
    WoohYeahJunior
    Dstock I looked at your thread not long ago and on the inside with the vinyl you've pretty much done what I was hoping to do!
    And from what you just Saud I don't I'll attempt it as it seemed a lot more complex than I thought it would be HaHa
    Soft! Have a go ya mug. Only one way to learn. Ive stuffed up countless things before.. gotta learn somehow.
    bumpak
    Post by bumpak »
    nice fto mate
    WoohYeahJunior
    bumpak wrote:nice fto mate
    Daniel2019 wrote:Soft! Have a go ya mug. Only one way to learn. Ive stuffed up countless things before.. gotta learn somehow.
    Fine! I'll look up a few tutorials and how it's done
    Thanks bumpak!
    That's the spirit :D
    WoohYeahJunior
    Will I actually need a heat gun or will a good hair do y he trick? HaHa
    Hairdryer may well work as well. Depends how hot it gets.You need it to get the vinylhot enough so it stretches around the item you are trying to wrap.
      Herron
      Post by Herron »
      I just did my broken centre console recently with a cheapo 10$ vinyl. Didn't prep or clean the surface and it turned out below average haha. I found that the breaks, regardless of being glued together still showed and because the wrap was cheap it had a hard time sticking, especially after being heated and stretched. I'd definantly listen to Dstocks and buy some good quality stuff.
      WoohYeahJunior
      Just for those that wanted to see my white one which was stuck out in the wilderness but have gathered enough money to tow it back to mine. It is now my parts car for my black FTO.
      Huh, different spoiler on that.
      WoohYeahJunior
      bjk wrote:Huh, different spoiler on that.
      I assume the person before me out that on and I the plan is to install it onto my black one.
      That.. is like the optional/spirit type A/B/C/R wing on FDs?
      Nice score.
      Was it you i just seen on the gateway motorway just then? black fto red version R wing
