Are they direct bolt up for the whole setup?MOR31 wrote:Have a look for some galant/legnum vr4 brakes. 294mm. Have some on my coupe. Pulls up real hard
GPX/GPvR or bigger brakes
Re: GPX/GPvR or bigger brakes
I do remember a thread about that a while ago actually.MOR31 wrote:Have a look for some galant/legnum vr4 brakes. 294mm. Have some on my coupe. Pulls up real hard
Completely forgot.
Daniel2019 wrote:Are they direct bolt up for the whole setup?MOR31 wrote:Have a look for some galant/legnum vr4 brakes. 294mm. Have some on my coupe. Pulls up real hard
FromThe 294mm setup from the legnum/galant VR4 (6A13TT) 'Pre-facelifts' are a direct bolt on to the FTO hub. No mods required. Also interestingly, the inner caliper is the same as the standard FTO one and uses the same brake pads. Which worked out great for me because I retained my relatively new EBC Reds![]()
viewtopic.php?f=10&t=26018&p=319695&hilit=294mm#p319695
Edit: Morel also posted in that thread.
That's from a series 1 VR4 yeah? They went to Brembos on the facelifted ones from memory.MOR31 wrote:Have a look for some galant/legnum vr4 brakes. 294mm. Have some on my coupe. Pulls up real hard
Bolt on upgrade too.
MOR31
Yeah pre face lift. Face lift went to 160mm bolt space but only went brembos as an added option
MagnaAstron_Boy wrote:Time to check out ASA for other Mitsus with that caliper!
3rd Gen V6, TJ on?Bennoz wrote:MagnaAstron_Boy wrote:Time to check out ASA for other Mitsus with that caliper!
I was kidding but with a 'there could very well be a Magna one that fits' undertoneAstron_Boy wrote:3rd Gen V6, TJ on?Bennoz wrote:MagnaAstron_Boy wrote:Time to check out ASA for other Mitsus with that caliper!
I'll look up the part number on ASA, see if there's any cross reference to other models. Only problem is that I only have the Jap data, not Aussie.
Then again, I could always take a wander down to Pick N Paymore & take measurements.
I have all the versions of ASA installed, so can do a bit more checking.Bennoz wrote:I'll look up the part number on ASA, see if there's any cross reference to other models. Only problem is that I only have the Jap data, not Aussie.
Might have a look on Sunday night when I return to the noise factory.
- Rinii
- vanadinite
The distance between mounting holes is 130mm isnt it? If so whats the possibility that these will fit?
http://www.ebay.com.au/itm/Brembo-4-pot ... 27d4ebc45a
Dont bid me up either any of you
It's not just the bolt spacing, but the offset of the caliper, therefore affecting the rotor, and the 2 mating.
May fit, may not...
Unsure which Brembos lawso has.
May fit, may not...
- vanadinite
Yeah i know, any have any ideas what their off?
- Lawso
- Penis Fingers
I'll take a photo tomorrow
but as far as i'm aware, i have brembos off an evo 5 that came off a black FTO dstocks bought, fixed and sold.
From what Dstocks has told me, I have an adaption plate or something which ends up making it a direct bold on, without having to do what bennoz has don (check his thread)
- vanadinite
I meant the brake callipers i linked, i knew about yours and of course ben's from earlier readings. Thanks though.
Well, they're not going to be off an FTO.
So fact is, there is a high chance they won't be a bolt on, you most likely, like Lawso, would need an adaptor plate made.
Unless the seller knows, there's no visual way of telling which car those particular Brembos that you linked are off.
- Lawso
- Penis Fingers
Just for reference here,
They do ned a tidy up, and new pads, but this is exactly how i got them off dwayne, as well as what i'm aware are EVO rotors
