Okay so 24 of these little buggers have just been replaced. Note the staining and sludge deposits.
All the oldies soaking.
I'm hopeing doing this might get rid of some of the crud so I can try and free them up and working again.
The crud I got off the underside of two rocker covers. Granted there is some old gasket in there too. Lack of regular oil changes anyone?
How important is car maintenance? I’m trying to point out is, well read on……
1. Running on water instead of coolant, resulted in corrosion over time and slowly blocking up the cooling system.
2. Lack of Gear box oil and regular oil changes more than likely contributed to, nah I reckon it buggered the gear box bearings.
3. Lack of regular engine oil changes has contributed to sludgeing up the engine. It certainly didn’t help the lifters.
4. Not changing or flushing the brake / clutch system. So far I’ve checked the clutch master and had to re-kit the slave. I bet I’m going to find all sorts of issues when I get around to doing the brakes.
How important is regular maintenance, second to beer…. Rant over, as you were.
