Sams Phase 2: Forging Engine
FtoSam
Post by FtoSam »
Hahahahaha... Awesome!
FtoSam
Post by FtoSam »
Righto... Pistons are on their way over from the states at the moment.
So that means only a matter of weeks before the car is done...
WOO HOO!!
sounds good :twisted: you will have to get some pics up as soon as you get it on the road :D
FtoSam
Post by FtoSam »
1st pic you will see will be me picking it up from JnR..
Then a few days later i'll have a nice little dynograph for ya...
Im praying for over 180kw... 200 would be nice.. 220 great.
I guess it'll depend on the turbo. i think it'll handle 16-18psi...
So i'll be capped for power till i get a GT35 or something to run 24psi in it.
lol sounds great and mean at the same time :twisted:
the one problem you will have now is getting off the spor when you put your foot down lol
FtoSam
Post by FtoSam »
aza013 wrote:lol sounds great and mean at the same time :twisted:
Yeh... trying to find a 2nd hand LSD for that...
Damn FWD!
nosman
Post by nosman »
aza013 wrote:
Damn FWD!
OMG do i see that correctly bro??? :lol:
FtoSam
Post by FtoSam »
nosman wrote:
aza013 wrote:
Damn FWD!
Rather a FWD FTO then a RWD Skyline or an AWD Subbie or Evo... :P
nosman
Post by nosman »
:cry:
FtoSam
Post by FtoSam »
quick update. Just spoke to david. Few probs have delayed the engine slightly. Should be ready around next tuesday or wednesday! Yay! So assuming it arrives at joe n ricks fri or monday, should be in by the next wednesday (5th) then tuned by the 7th. Which is about 2 weeks away or so. Bout to give rick a call to make sure the engine is out. And double check it will only take 2-3 days to put in.
jonowong
Post by jonowong »
i want a dyno print out bitch!
FtoSam
Post by FtoSam »
yeh yeh... i'll put one up as soon as i get it
200kw atw is the magic number... thats what i want any more is cream..
jonowong
Post by jonowong »
bring it down to sydney and let me have a go at it!
FtoSam
Post by FtoSam »
ahahahah... unlikely...
maybe if you pay for the 10 tanks of fuel....
jonowong
Post by jonowong »
it would be cheaper to get it towed here! :lol:
FtoSam
Post by FtoSam »
Righto... just paid the bill... my bank account hates me right now... lucky its pay day tomorrow...
Engine leaves perth in the morning... hoping to be at JnR either friday or monday...
FtoSam
Post by FtoSam »
Copy of the receipt:
(not a bad price me thinks)
ENGINE RECONDITIONING / REPAIR WORK
14.00 LABOUR $65.00 HOUR
1. Strip Engine - engine number AQ7270
2. Acid clean engine block and cylinder heads
3. Surface grind engine blocks and cylinder heads
4. Bore and hone engine block
5. Service Cylinder heads, cut valves and seats
6. Perform mild port job on cylinder heads
7. Assemble short motor with ARP Head and Main Stud Kits
8. Assemble short motor with CP Forged low compression pistons 8.0 : 1
9. Assemble short motor with Forged Conrod Set
10. Assemble cylinder heads to short motor
11. Replace waterpump, timing belt and hydraulic timing belt tensioner
12. Fit remaining plastic covers and anciliary items
13. Prepare engine on pallet and ready for despatch
$910.00
6.00 BORE EACH CYLINDER $12.50 CYL $75.00
6.00 HONE EACH BORE $12.50 CYL $75.00
1.00 SURFACE GRIND 6CYL ENGINE BLOCK $140.00 EACH $140.00
3.00 ACID CLEAN ENGINE / CYL HEAD $30.00 EACH $90.00
2.00 SURFACE GRIND CYLINDER HEAD $35.00 EACH $70.00
1.00 FORGED PISTON SET 6A12 CP $1,640.00 SET $1,640.00
1.00 FORGED STEEL CONROD 6A12 $2,100.00 SET 6 $2,100.00
1.00 VRS GASKET SET $300.00 EACH $300.00
1.00 6A13 DOHC TURBO CAMSHAFTS $350.00 EACH $350.00
2.00 ARP MAIN STUD KIT $110.00 SET $220.00
2.00 ARP HEAD STUD KIT $200.00 EACH $400.00
1.00 NOK TIMING COVER SEAL $15.00 EACH $15.00
1.00 REGRIND 6 CYLINDER CRANK $190.00 EACH $190.00
1.00 CONROD BEARING KIT $45.00 EACH $45.00
1.00 MAIN BEARING KIT $50.00 EACH $50.00
1.00 TIMING BELT HYDRAULIC TENSIONER $150.00 EACH $150.00
1.00 TIMING BELT STANDARD $135.00 EACH $135.00
1.00 WATERPUMP ASSY $110.00 EACH $110.00
Total Engine Reconditioning / Repair Work: $7,065.00
PARTS
1.00 FLYWHEEL CHROMOLY 5.2KG 7 BOLT $500.00 EACH
For FTO Model V6 vehicles - crank face diameter to be remachined larger
$500.00
7.00 FLYWHEEL BOLT 11X28.5MM $5.00 EACH $35.00
Total Parts: $535.00
FREIGHT CHARGES
1.00 FREIGHT CHARGES TNT OVER 7KG $200.00 NETT
1. Freight from customer to RPW
$200.00
Freight from RPW to Customer
$200.00
Total Freight Charges: $400.00
MISCELLANEOUS
1.00 WARRANTY PERFORMANCE ENGINE $0.01
The above work / product is limited garaunteed for a time limit of 12 months / 20,000km,
subject to cause of failure, from date of invoice where goods are supply only, or date of
installation and odomoter recorded above where fitted by RPW Service Centre.
Any queries or claims regarding warranty need to be presented to RPW Service Centre before
proceeding with any repairs or work. RPW Service Centre reserves the right to repair / replace
faulty items etc at own expense. Work performed without RPW Service Centre permission will
not be considered a warrantable financial claim.
This engine has been prepared for high performance naturally aspirated / forced induction use,
and as such will require significant dyno tuning time in order to be tuned correctly. Any engine
complications, linked to such tuning will not be considered a warrantable claim. Due to the
intended use of such performance modifications, including forged pistons etc, any warranty
claim will need to be strictly inspected by RPW prior to any acceptance of any warranty.
Payment of this invoice is full acceptance of the above terms and conditions and there is no
$0.01
Carried forward >>>>>
GST amount $727.27
Total incl. GST $8,000.01
Rounding $-0.02
Price includes GST[/b]
AMACHA
Post by AMACHA »
8grand + the close ot 10grand with your turbo setup wow. Who are oyu bill gates lol.
OMG.
Delvance
Post by Delvance »
Holy hell...
