Nvr2lows 6a13 conversATION WITH BEN ABOUT HIS CONVERSION
Im sorry bro but something is wrong here. Even with an 2.5 exhaust you should be hitting way higher numbers than that. Also your running 6a13 ECU right? That should alos be hitting higher numbers without the need for a haltech.
Do they have the right plugs in there? Running rich shouldnt make you run that lower number. Put a rrfpr and lower the fuel pressure to stop ypu running so rich.
Let me think about it more tonight and all reply with a bit more info tomorrow.
- aza013
- NSW Coordinator
- rock_it
Hmm ... I put the 4G63 into my Sonata, with stock turbo, and just a pod and ecu, and got 145.1 @ the wheels ... So yeah, I would have thought you would get a lot more ..
- nvr2low
yeah i understand guys i am confused as much as you are.
all my piping is good no leaks as it makes it to 10 psi no worrys.
they say it is running really really rich like stupidly lol.
i will get a quote 2morow for how much a interceptor is installed and tuned. i want this thing to make some good power measures.
all the plugs are in correct and everything as the motor runs fine and boosts up fine.
i am so confused simon think hard lol
- nvr2low
Mate, sitting 3000km trying to guess from the little info i have is nearly impossible. However, i think it could definitly be causing mixture problems and also MAY be causing the problems. BUT BY THE SOUNDS OF IT I THINK YOU HAVE MORE THAN ONE ISSUE.
If this guy is so good how come he cant even tell you WHY your running rich?
DO YOU HAVE A FPR ON??????
- nvr2low
- nvr2low
K it's been along time for the update lol new motor is installed and running great. Currently running it in for awhile. Then will be changing all fluids and installing the microtech lt10 I bought and fuel pressure regulator will also have a 3 inch exhaust on the car which will be 2 cannons 1 on each side of the rear.
With the new motor we installed the adjustable exhaust cams and all I can say is sh*t the exhaust is a lot louder now than it was before. Also did a full service on it.
All the intercooler piping is now red and intake plenium is black with red flake. I am currently looking at buying a evo carbon fibre bonnett as the temps are still high but the motor is not overheating now like last time.
- nvr2low
well fixed the over heating problem i hope i flushed the radiator again and put some water wetter in from redline and can say it is running sweet. i have bought my new bonnet so that should be here next week and this should also help with cooling the engine bay. i will get some pics up of the car later when i go take some.
The new ecu is on hold until the workshop has slowed down abit and i can get it in their to be done in and out as quick as possible. Or i will take it somewere else and see if they can do it.
cheers mitch
cheers mitch
- nvr2low
2 motors 3400
intercooler and piping 1300
bov 250
thermo fans 120
labour and workshop total 5000 for installing both motors
microtech lt10 1100
microtech tune on the 24 1200
new ab style bonnet 1395
proberly around 15k man lol including timing belt and all new seals and adjustable exhaust cams.
But the car is running good now and I am happy with it
bov 250
thermo fans 120
microtech lt10 1100
- koolio1234
- nvr2low
hey guys got my new microtech here in my hands now and will be installed on the 24th of this month.
here is a pic.
[img][img]http://img163.imageshack.us/img163/961/ecuq.jpg[/img][/img]
here is a pic.
