And while I was out getting my sick certificate for work I heard an almighty snap pulling into a driveway.
New and improved two-piece sway bar.
Yeah I must imagine the stress point would be fairly consistent. With any luck the Whiteline one will be more up to the task. At least I'll have matching front and rear.yotka wrote:That looked similar to how mine went too.
Are you getting it from WILL?bjk wrote:Yeah I must imagine the stress point would be fairly consistent. With any luck the Whiteline one will be more up to the task. At least I'll have matching front and rear.yotka wrote:That looked similar to how mine went too.
Thanks for the offer, but I will politely decline.Bennoz wrote:f**k
Chassis. Subframe is bolted up with the control arm bracket to the chassis as far as I understand. I think Tim was saying it's made a hole that he can see the nut through so he might be able to fish it out and replace it or tap it or something. I don't really know how to explain it cause it's hard to visualise.spetz wrote:Does the bolt that goes into control arm bush bracket tighten on the chassis or on the subframe?
Are you able to use a slightly oversize bolt or anything?
Evo gear, no adapters.Technikhaus wrote:them brakes...
Wish we could get them here, but you can't certify adaptor plates
That's right, you swapped out hubs etc too didn't you?bjk wrote:Evo gear, no adapters.Technikhaus wrote:them brakes...
Wish we could get them here, but you can't certify adaptor plates![]()
(expensive mod though lol)
